08-29-2020, 03:29 PM | #1 |
Violent wobble in new POL rack & pinion install
Just finished up installing Performance Online's power rack kit. The install was pretty basic. I’m using a new pump as well. I followed GMs procedure for bleeding out the air. So I’m ready to fire this thing up and see how it works. Start the truck and let it idle a bit, while visually inspecting for leaks or any clearance issues. Everything looking good so far. Get in the truck and grab the steering wheel to see how effortless it is now, and as soon as I start to turn the wheel , the devil takes over and starts violent jerking the wheel back and forth so hard I thought it broke both my wrists. WTH! I shut the motor down quickly.
Anyone have any ideas as to what’s going on?
1972 C30 Grain Hauler, 350/400 1967 1500 GMC Stepside SWB, In Transformation Process 1967 RS/SS Camaro 350/TKO600 |
08-29-2020, 04:46 PM | #2 |
Re: Violent wobble in new POL rack & pinion install
Fluid lines on backwards?
08-29-2020, 05:42 PM | #3 |
08-30-2020, 08:49 AM | #4 |
Moderator
Did you contact POL and ask them yet?
09-14-2020, 12:19 AM | #5 |
Was the pump specified for rack an pinion? If not you might want to install a flow restrictor.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
03-07-2021, 09:55 AM | #6 |
I know I am late to this thread but back in the day I had the same problem on a corvette I was working on. Power steering lines backwards. Very dangerous to your arms
03-08-2021, 10:26 AM | #7 |
[sarcasm] I love when someone asks for solutions to an issue.... options are provided/discussed, & then there's no definitive resolution provided so that others might benefit. [/sarcasm]
03-08-2021, 04:40 PM | #8 |
I thought that was odd too Scoti. This was also his last post?
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
03-10-2021, 09:16 AM | #9 |
This is a pretty common occurrence.
Sounds like you need to bleed the air out of your system. If you Google "bleeding power steering" you can find all sorts of write ups. Basically with the truck off (not running) and the front wheels supported off the ground, you keep turning lock to lock slowly. With the cap off your reservoir you will see the bubbles from the air escaping the system. Repeat until you see no bubbles/air. Thanks Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
