Old 08-29-2020, 04:15 PM   #1
Corts60
Just here to tinker
Corts60's Avatar
Replacing VSS Buffer?
Hi All,
I'm trying to get the cruise control working in my '86 Suburban and I've narrowed the culprit down to the VSS buffer not giving a signal to the cruise control module. All other components were tested and function correctly.
I know they no longer make these VSS buffer units so I've been doing some research. I see that Dakota Digital makes a pass-through signal generator that goes inline with the speedo cable at the transmission. This unit produces 8000 pulses per mile. The factory control module needs 2000 pulses per mile. Dakota Digital also makes an interface that can translate the 8000ppm to 2000ppm for the factory cruise to use as a signal.
My question is: has anyone tried this out before?
Thanks!
Old 08-29-2020, 04:18 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: Replacing VSS Buffer?
So the pic is the factory VSS buffer.
I want to use these two components made by DD to replace the original unit.
https://www.summitracing.com/parts/d...AaAvllEALw_wcB
https://www.ebay.com/itm/Dakota-Digi...YAAOSwXKdeMeB0
Old 08-30-2020, 08:16 AM   #3
Mathew21
Mathew21's Avatar
I have an extra untested one I will send you if you for the cost of shipping.
It only has original paint once
Mathew21 is offline   Reply With Quote
