Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > Welcome Area
Old 09-11-2020, 10:29 PM   #1
Justin71105
Finally I can post
Joined back in December and finally am able to post and show the truck I purchased and have been steadily working on since then.
It is a 1964 C10 which I have semi-repaired most of the metal on, mostly been patch jobs.
I replaced both rockers inner/outer, partial parts of the floor, door pillars and kick panels. Repaired bed sides mounting rails where it bolts to floor and door bottoms inner/outer.
I have rebuilt steering and suspension completely. Added power brakes, disc in front and power steering.
It has the complete front end from a 74 C10 with all new parts.
Currently finishing the drivers side door, then still need rear frame fuel tank (Boyd welding tank), lines, interior and power train.
This has been pretty much a from scratch build, started with a rusted out body and a frame.
Have done a 3/5 drop on it with C notch.
I have several hundred pictures of the process, wish I could have shared them over the past few months but the website would not let me post anything.
Justin71105 is offline   Reply With Quote
Old 09-11-2020, 11:00 PM   #2
Justin71105
Re: Finally I can post
More pics
Old 09-12-2020, 08:02 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Wow that's some great work. Welcome.
Old 09-12-2020, 09:31 AM   #4
Justin71105
Replaced the front roof sections, inner and outer.
Was a bear to weld in place, I am a novice welder and was using a flux core at the time. Now have a decent mig set up i am using for the doors and hood...wish I had it back when I was doing the majority of the rust repairs.
Old 09-12-2020, 09:35 AM   #5
Justin71105
Here is the passenger door, cut out inner/outer bottoms and welded in patch panels. Came out ok, better than having the whole bottom rusted out I guess. Only issue I had was the heat got to the outer skin and bowed it in.
Cant really notice it unless you get a good side profile view and really look at it.
Old 09-12-2020, 10:15 AM   #6
cwcarpenter98
cwcarpenter98's Avatar
Welcome! Looks like you are well on your way to having a really nice truck.
We love seeing pictures on this site. Here is the link to the 60-66 build thread page for ya
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 09-13-2020, 10:21 PM   #7
vetnat
Wow! Great work! Welcome.
1961 GMC half ton, short step, Canadian model. Just starting work on it.
vetnat is offline   Reply With Quote
Old 09-15-2020, 10:57 AM   #8
Justin71105
Searching for a motor now, want to get it in the garage and cleaned up this fall and ready to drop in.
Plan is for an LM7 and 4l60e combo.
Edit: Found a 5.3L - LM7 today and will be picking it up Tuesday.
1964 C10 Resto-mod
5.3L - L59
Old 09-21-2020, 04:41 AM   #9
70LonghornCST
Moderator
70LonghornCST's Avatar
Very nice! Just like my dad's old truck. Except he never fixed it up (wish he had at the time). I can't wait to see it progress.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 09-21-2020, 07:52 PM   #10
Klas
Junior Member
Klas's Avatar
Looks like you're on your way. BTW, your welds are much prettier than mine. The payoff will be when you drive it. Stick with it, you're doing good!
Klas is offline   Reply With Quote
