Old 09-12-2020, 11:00 PM   #1
dag19
dag19's Avatar
Leaf springs to trailing arms
Alright. I've searched and searched on here and have been unsuccessful in finding out if it's possible to change from leaf springs to trailing arms....and if it's a good idea? What's better...leafs or trailing arms? Give me the pros and cons of both. I want a setup that will hook up.
70 SWB, 6.0, big cam, turbo, 4l80.
dag19 is offline   Reply With Quote
Old 09-12-2020, 11:35 PM   #2
gmc684x4
Re: Leaf springs to trailing arms
Yes it do able
The bigger differences are from the c to k series frames
A c series c10 c20 frame will be wider at the diff to provide support for the coils
Your trailing arm cross member is already in your truck its only missing the trailing arm brackets
You will have to add the brackets for mounting the coils to the frame shocks will need to be relocated
Ece has a kit to with trailing arm axle mounts shock mounts and panhard bar bracket
gmc684x4 is offline   Reply With Quote
Old 09-12-2020, 11:43 PM   #3
truckster
truckster's Avatar
In my experience (I've owned about a dozen of these trucks) for 2WD trailing arms are better than leaf springs. In my opinion, they ride better and hook up better.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 09-13-2020, 02:14 PM   #4
P7M89MM
P7M89MM's Avatar
See my build. Link in signature.
71 Cheyenne LWB - RideTech Air, zz502, 20" Torq Thrusts
16 Sierra - Bilstein 6112/5160, 33" Duratracs, Method Race Wheels, GMPP Intake, Borla Exhaust
15 4Runner - Icon Coilovers, 33" Duratracs, Pro Comp Wheels, NFABs
16 Malibu Response TXi
P7M89MM is offline   Reply With Quote
Old 09-13-2020, 02:20 PM   #5
camtoys1
Yes very easy and much better ride
camtoys1 is offline   Reply With Quote
Old 09-13-2020, 04:39 PM   #6
gmc684x4
Here are a few pics of the back cross members and a reference picture of K 10 truck you can see how the C frame is wider at the axle
I was going to use this truck for parts to convert a 69 C20 to 1/2 with trailing arms going to build a different truck now and use it to convert over to 5 bolt
Old 09-14-2020, 03:01 AM   #7
dag19
dag19's Avatar
Thanks for all the good info. Seems like trailing arms are the way to go but with a little added expense for the conversion. I see ECE has a kit. Does anyone else have any other recommendations? I won't be putting air ride on it.
By the way, great rig P7M!
Old 09-14-2020, 08:27 AM   #8
Mike C
Mike C's Avatar
Unfortunately, ECE is out of business.
Cal-Trac traction bars allow the leaf spring trucks to hook up as well as the coil trucks. It is more expensive to get the height where you want it on the leaf truck, but running exhaust is significantly easier.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-14-2020, 11:47 AM   #9
P7M89MM
P7M89MM's Avatar
Thanks. RideTech does offer a coilover version. Still $$.
Old 09-14-2020, 12:17 PM   #10
beaterku
beaterku's Avatar
I did this exact conversion. I documented the whole process on YouTube. Check my channel out. Search for Rusty Wrenches on YouTube. I ended up buying a back half of a coil frame and using all of the crossmembers, brackets, etc... to complete the conversion with a Ridetech Streetgrip kit. But you can do it will other suspension parts as well.
Hope it helps you out.
-Nick
beaterku is offline   Reply With Quote
Old 09-14-2020, 12:58 PM   #11
dag19
dag19's Avatar
Cal-tracs were the way I was going to go but now not entirely sure. I've heard good things about them but I'd have to buy new leafs for just under $500 and cal-tracs for $450. Adds up there as well.
If I do go with trailing arms, would it be best to remove the leaf spring mounting brackets?
Old 09-14-2020, 01:01 PM   #12
dag19
dag19's Avatar
-Nick
Sweet, thanks Nick! I'm definitely gonna watch your channel.
Old 09-14-2020, 01:12 PM   #13
nikwho
nikwho's Avatar
I swapped my '68 GMC over from leaf springs to trailing arms. It was an easy swap, and well worth the effort. If you're gonna source a stock set of trailing arms, I think that it would be worth your time to make sure that you find a set without any cancerous rust, and spend a little time stitch welding and reinforcing them. I was happy with my swap!
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 09-14-2020, 01:27 PM   #14
gmc684x4
ECE is still in business it is now owned by the Holly group
When i get to the stage of suspension i will be going Ece as they have many great reviews on here and elsewhere
One company i would steer away from is cpp with there unknown spring rates and many reviews of rough rides
Old 09-14-2020, 07:45 PM   #15
BigBird05
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
BigBird05 is offline   Reply With Quote
Old 09-14-2020, 09:11 PM   #16
dag19
dag19's Avatar
Deal! Now I may just have to go through with the conversion if I have a taker for my spare parts.
conversion, hook up, leaf spring, traction, trailing arms
