![]() Join Date: Jul 2015
How to secure hubcap to rim
That’s the problem.
There are no clips, and the hubcaps were glued to the old rims with silicone RTV sealant. I was thinking about drilling two or four small holes through the hubcaps and drilling/ tapping the rim with a #10-32 screw. However, I hate to destroy the hubcaps.
1963 C20, small window, long bed 292, 4-speed |
![]() ![]() ![]() Join Date: Jan 2018
Re: How to secure hubcap to rim
Maybe you could add some clips to the wheel that will hold the hubcap in place?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
![]() Join Date: Oct 2009
#4 | ||
I was also thinking a machine screw would deter a thief from just popping off the hubcap.
I did find this...
http://www.laroke.com/larryk4674/smo...er/hubcaps.htm Might be worth looking in to. I wonder if anyone has ever drilled their hubcaps to secure them to the rim.
https://www.stovebolt.com/ubbthreads...&Number=723557 Follow the links on this site it shows you how to use the 1/2 ton clips on 3/4 wheels. Also if you have a junk hubcap to cut up also helps place clips.
There is also few threads about this. Try the search function.
Moderator
![]() Join Date: Dec 2012
Those are clip caps. You need to screw clips to the wheel.
Those look to be the correct 61-63 clip hubcaps for your truck. Your truck did not have the original wheels on it when you bought it
![]() Join Date: Aug 2008
Original rims would have looked like this.
