09-19-2020, 07:53 AM | #1 |
Question - 65"-66" axle to replace a 12 bolt truck
Does anyone know of a 65 inch to 66 inch wheel mount to wheel mount GM 6 lug axle that can be converted to replace a leaf spring 12 bolt that is 62 inch?
I am not sure of the widths of the newer like 1988 - 2007 or so. I will need a 3.73. I can remove/replace perches and shock mounts and can usually overcome e-brake obstacles. I want rear drum. thanks
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
09-19-2020, 08:14 AM | #2 |
Re: Question - 65"-66" axle to replace a 12 bolt truck
I think the newer the axle the wider it is. I've been looking for axle widths and only finding stuff for rat rods and hot rods. But I wanna say 73 and up might be close to what you need. Discs didn't come out till 99-ish...
09-19-2020, 12:54 PM | #3 |
I had a 2006 K1500 and the wheels had a lot of rear offset. This makes me think the axle is longer. It was drum. I am thinking the square bodies up to 87 were 62 inch on the half tons. Been wrong before. Axles are not cheap at the junk yard. I will look on craigslist.
09-19-2020, 05:10 PM | #4 |
I have a 96 and 97 1/2 tons, one a 2wd the other a 4wd. I could measure the housing, taking the wheels off is a PITA, and being lazy lol...
09-19-2020, 08:29 PM | #5 |
I appreciate that but do not go to that effort unless you have another reason.
09-19-2020, 09:20 PM | #6 |
My 94 4x4 is 68 inches from wms to wms.
Six lug wheels. |
09-19-2020, 10:05 PM | #7 |
60-66 Nut
The '71-'87 ('91) 10 and 12 bolts are 63.5" wide. The '88-'98 10 bolts are 64.750" wide.
09-20-2020, 10:02 AM | #8 |
That 64 3/4 looks like the animal I need - I take 2wd. I will be looking for a 3.73 in that model. I think this will more align my back wheels with the front wheels which is a 84 K10 gm 10 bolt. That way I will need no rear spacers on my 59 gmc. I had a new 78. I think all the square bodies had the stock issue of the front track wider than the back. Thanks guys.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 09-20-2020 at 10:08 AM. Reason: words |
09-20-2020, 06:19 PM | #9 |
I'm not 100% but I think the axle housings are the same between 2wd and 4wd. If any difference in width it would be from the axle shafts, backing plates and drums. Again I can measure em tomorrow, since I want to know myself. The Yukon has 3.73 and is 4wd, the tahoe has 3.42s and is 2wd. I plan on doing an SAS to the Yukon, and would like to put 3.73s in the tahoe with a posi I picked up. Figured have some fun lol...
09-21-2020, 07:39 PM | #10 |
driving is in my blood
They are half or less then a diff rebuild around here, so I call them VERY cheap.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
09-22-2020, 09:25 AM | #11 |
Granted it’s been awhile but local yard here has em for like $125, regardless of what it is. Wait, 8 lug, they charge more for those. But it’s not much more....
09-22-2020, 02:24 PM | #12 |
I am checking with Strickers.
09-23-2020, 10:22 AM | #13 |
the Trailblazer SS has an approximately 66.25" WMS 14 bolt axle. I would think that you could bolt on a late model truck drum brake. I do know where there is a 4.10 axle sitting that could be had for a great price. PM me if you are interested.
Joe |
09-23-2020, 06:12 PM | #14 |
But will it have standard 6x5.5? Thought they had some goofy pattern....
09-23-2020, 10:08 PM | #15 |
60-66 Nut
The trailblazers are 6 lug but it is not 6 x 5.5". I don't remember exactly what the bolt circle is.
09-23-2020, 10:51 PM | #16 |
09-24-2020, 10:48 AM | #17 |
yup, you guys are correct. I learned something new. I lost my source for free re-drilling of wheel patterns, so no luck there. I picked this axle up with a complete AWD setup from a Trailblazer SS (minus engine) when I was thinking of doing an AWD C10.
09-24-2020, 07:37 PM | #18 |
Does the regular trailblazer use a different axle? My backing plates for my rear disk conversion on my 98 uses TB parts, bolt right onto the 10 bolt.
09-24-2020, 09:39 PM | #19 |
Backing plate to housing pattern is the same...truck & Trailblazer. Its the wheel bolt pattern that is different. Must be using truck rotors? Lorne
09-25-2020, 03:17 AM | #20 |
The junk yards around here must like to crush the 88 - 98's. I may be able to go up to a 2007. The 2006 I used to have had the setup I want, but I am not sure of the wms to wms distance yet.
I am not sure what u joint they use. It will get there one way or another. I have a friend of a friend from Strickers looking for a fit.
09-25-2020, 04:30 AM | #21 |
I am installing an AAM 11.5 from a 2006 2500HD, a 1 ton axle in my 72 (should be same width as 1500). I wanted factory disc brakes in the rear. Do not have the WMS to WMS measurements in front of me but I can measure for you. When doing research I recall it was very close to the Dana 60 front I will be using. The Dana 60 front measurements are identical to Dana 44 IIRC. I know the rear axle is shorter on stock 4WD for some reason that I do not know.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
