I've been tinkering with the truck lately and have not found any ground straps, the ones by the filler necks were broken the only other is from the alternator bracket and headlights which is trashed.
So my question is how many ground straps are needed. Ordering a wiring harness from eBay and want everything to be there and done right. '85 C10 As always thank you for your time and I look forward to hearing back from y'all.
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
Post Whore
![]() ![]() Join Date: May 2015
Re: Ground Straps (How Many?)
I believe in lots of grounds..battery to engine...engine to frame... cab to frame...bed to frame..at a minimum
My 75 has one from the firewall to the passenger valve cover bolt and the primary battery cable runs to the alt bracket. Apparently fine for a new truck. But unless you are doing a frame off restore, best to assume that corrosion exists in a lot of the body to body bolt connections and add a few more grounds.
IIRC, headlights ground to the core support so a ground from battery to there Taillights ground to the bed so as mentioned already, bed to frame. They are a PITA to replace but check the grounds from fuel tank sender(s) to frame. If your battery cable runs to an engine bracket, I would run a heavy ground from engine to frame. There is a ground bus high up under the driver's side dash that often sports corrosion. Another PITA thing to get to. |
Just here to tinker
![]() Join Date: Jun 2008
x2 + battery to body
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
I was told by my engine builder that they see a lot of corrosion on aluminum heads from poor grounding issues (electrolysis). I did an LS swap on my C10 and put two large grounds from the block to the frame, two from the block to the cab, and two to from the cab to the frame.
I believe factory was just a small one from the back of the passenger head to the cab, and one from the rear bottom of the cab to the crossmember. |
![]() ![]() Join Date: Jul 2002
This is what I have ob mine and seems to eliminate any gremlins
Battery to frame that frame spot to the engine block that frame point to radiator support Engine to firewall (I have a 6, when I had V8 I ran one from each head to firewall) Body to Frame (2 - one on each side) Bed to frame Fuel sender to frame Taillights to frame I also have a grounding buss bar behind the glove box that I ran my stereo and a few other interior items to, then the bus bar to that battery frame tie point. It maybe overkill, but it has always taken care of any weird issues I have had on this or past trucks
Im in the rust belt and have trouble keeping grounds simply on the truck. every time I replace one I use the Hobart insulated wire and their copper fittings with heat shrink that's been lasting till the truck melts into the asphalt.
#8 | |
I'd go battery to block, then frame. Otherwise I agree. |
#9 | |
I run battery to block. Block to frame. Frame to core support. Cab to block Tail lights to bed. Bed to frame Make them nice clean grounds. |
