Old 10-05-2020, 06:33 PM   #1
Andyking1203
69 c10, ls swapped lwb..
so I bought the truck back in April of this year, I was lucky and found it locally!! It started off (as many projects do), fix what I was told was wrong and drive the truck!! So once I got it home I replaced the points distributor in the 250 6cyl with a hei setup, bought a battery and it runs!!! Was super excited!!! Until I went to turn the key, and it kept running!!! Wth!!! That turned into finding a wiring rats nest!! Basically had to pull the power plug off the distributor to kill the motor!! Not good!!!
Will post again the continuance of the long road im on!!!
Andyking1203 is offline   Reply With Quote
Old 10-05-2020, 07:19 PM   #2
Andyking1203
Re: 69 c10, ls swapped lwb..
So after getting it running I started cleaning out the cap (removing the seat and vinyl floor covering), i found LARGE HOLES, in the floor.. (wasnt told about this)!!! What I was told was wring, rear trailing arms, possible brakes (they did work), and bad gas!!
So after finding all this wrong with the truck, I decided it was gonna be a complete rebuild!! So at this point I built a poor man's garage, and made a work space.. not the greatest but it works!! After building it, I started disassembly of the front end of the truck, sold the motor and trans quickly!!! I replaced the entire front suspension, upper and lower a arms, 2.5" front drop spindles.
More pics
Old 10-05-2020, 07:22 PM   #3
Andyking1203
Also found some rot in the bottom of the front crossmember, so had to fix that with a piece of steel plate!!
More pics!!
Old 10-05-2020, 07:31 PM   #4
Andyking1203
So at this point i turned the truck around, i plan to run old school rally wheels, got 6 from a friend for free!!! At this point i started on the rear, first thing was removeing the bed!! And as you can see there was a lot of junk on the frame!! The last pic you can see the donor lurking over in the corner!!! More on that later!!!
Pics!!!
Old 10-05-2020, 08:11 PM   #5
Andyking1203
I then started by lifting the cab, it was a little scetchy!!! Then I ordered more new parts.. new tubular trailing arms, 4" lowering springs crossmember with adjustability!! And duel exhaust holes!!! As well as 5 lug rear conversion!!! O ya did the 5 lug on the front as well!! Plus my cheering squad!! The wife!!
Pics!!
Old 10-05-2020, 08:13 PM   #6
Andyking1203
More pics
Old 10-05-2020, 08:24 PM   #7
Andyking1203
Know I'm just cleaning and painting the frame.. then I found more rot in a crossmember.. was kinda irritated by this!!! Found a local mud truck builder to build me a new one,(waiting a few weeks for that)!!
Pics!!
Old 10-05-2020, 08:28 PM   #8
Andyking1203
More pics...
Old 10-05-2020, 08:37 PM   #9
Andyking1203
This is pretty much where I'm at.. once the crossmember is built ill bolt that in. Need a few parts for the rear end before it goes back in..
Ok onto the ls!!! I work for fedex, and I bought it for dirt cheap, and drive it home!! It has a little over 200k on it, it has a 4l80e in it, o and the motor is the lq4 6.0!!! The plan is to build and possibly stroke it!! But there is also the possibility of a turbo setup!! Thenonly thing thats been decided on the motor is the sheetmetal intake!!
