10-13-2020, 01:33 PM | #1 |
Another Chinese Part Story - This Time It's ACDelco
Here is a cautionary tale for those of you out there running an HEI.
I installed an HEI two years ago that I got from a mid-70's C20. When I installed the HEI, I spoke with an old-timer at my local NAPA and he advised me that these modules can go out at random and that I should keep a spare module in my tool kit in my truck along with all of the necessary tools to replace it (a 1/4" nut driver, a flat head screwdriver, and a Philips screwdriver). They didn't have any in stock and I didn't need it right away, so I went home and ordered an ACDelco module to keep as my spare, but was a little disappointed to see that it was made in China when it got to my house. I figured that since it was ACDelco it should still be a quality part and moved on with my life. It ran great until a few months ago when I started chasing what I thought was vapor lock. I was stuck on the side of the road and thought to myself "what about the ignition control module?" I replaced the chip, had it running after about 10 minutes, and continued on my way to pick up a yard of gravel. The wife didn't even notice I took longer than expected! That week I went to NAPA and got another module to keep in my tool kit. This time, I bought a NAPA brand chip FOR THE SAME PRICE, which is made in the USA by Echlin. About two weeks ago, I started having problems that felt like I was dealing with an electrical short, but it was intermittent and I couldn't trace it down. This morning I swapped the chip out and she's running just fine now! I'll report back in the future if I have any problems with the Echlin chip, but I highly doubt it will happen.
1968 GMC C2500 Long Bed Fleetside Last edited by Willys_MB; 10-13-2020 at 01:39 PM. |
10-13-2020, 01:53 PM | #2 |
Post Whore
Re: Another Chinese Part Story - This Time It's ACDelco
I had an HEI failure myself last week. (Post 707 in link) I wasn't able to get the truck running with a different module so I swapped distributors and got going. The point is that there is a pickup coil that can fail also.
You didn't mention if you are running a fact HEI or an aftermarket one. So it is likely you have a 35 plus year old pickup coil or one made overseas to the lowest bidder.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-13-2020, 04:22 PM | #3 |
Don't know if they provide a di-electric grease with they new module but back in the day when we replaced a module at the dealer ship there was a small grease pack that you put on the bottom of the module. I believe it was to help heat transfer.
10-13-2020, 04:39 PM | #4 | |
The original one I pulled off a few months ago didn't have any on there, or maybe it just dried up!
1968 GMC C2500 Long Bed Fleetside |
10-13-2020, 04:41 PM | #5 | |
10-13-2020, 05:13 PM | #6 |
Not that I have one, an HEI, but I'm curious why these modules go out so often. What is the root cause? Sorry for the side distraction.
10-13-2020, 06:05 PM | #7 |
20' Daredevil (Ret)
I'm not sure how often they fail, statistically speaking. Hope I don't jinx myself -- I'm still running the same HEI that I bought used and installed about 40 years ago.
10-13-2020, 07:03 PM | #8 |
Usually it's heat. That's why the heat transfer grease or paste is so important.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
10-13-2020, 07:20 PM | #9 |
Yes, it's impossible to tell I think. Every time somebody asks here on the forum, and the question is asked did you use heat sink compound under it, the discussion usually deteriorates into discussion about dielectric grease or some other substance that you're not supposed to use, and we never find out from the original poster what exactly was used or if anything was used. Willys_MB is an exception to that and actually told us what was used. I have my doubts about silicone based compounds. The correct heat sink compound is a sticky usually white thick paste and is not similar to anything silicone I've ever seen. How it is applied makes a difference as well. Only a very thin spread of it is needed for optimum heat transfer. I think when I change mine I will not trust a packet that came with the module, especially if it is unmarked and appears to be anything like grease or silicone. I don't trust whatever packet of sauce or other substance some Chinese manufacturer throws in a box with a car part. I plan to buy a small tube of high performance computer processor compound. Any use of the inappropriate type or amount of compound should not be considered in any discussion of how long a module lasts, but how do you determine what was used or what people have done and make a count? I guess I'm going to jinx myself like Stocker did, my module is ancient and working fine, too.
10-13-2020, 07:35 PM | #10 |
Who Changed This?
Back when I worked as a mechanic, the primary failure mode for an HEI was burn-through of the rotor due to lack of maintenance. They'd generally burn through at about 14k miles. I replaced hundreds of rotors (and sold a tune-up at the point), a handful of modules and ONE pickup. Fast forward a few decades, now it's all cheap Chinese crap, and module failures are far more common. I guess I got lucky- I bought a Mallory HEI that I put in an an engine in y2k that is now in my truck and working fine. It's only ever seen a cap and a rotor...and one vacuum advance can.
10-13-2020, 07:36 PM | #11 |
Had the exact same thing happen to me two weeks ago. AC Delco part. Replace with a Borg Warner made in USA.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
10-13-2020, 08:02 PM | #12 | |
The Older Generation
I always use a thin coat of Arctic Silver computer processor, heat sink compound. I have never had a module failure using this. LockDoc
10-13-2020, 08:46 PM | #13 |
I forgot about the rotor burn thru. I think was typically caused by bad plug wire that was arcing to the exhaust manifold or block. Early days of HEI GM had some quality/design issues with the modules and replaced tons of them under warranty.
10-13-2020, 09:16 PM | #14 |
I've never had an HEI module burn out in the many various GM vehicles I have had with that ignition
10-13-2020, 09:26 PM | #15 |
It was my (mis?)understanding that the only failure mode was digital: on/off. In other words, I thought that they either worked fine or didn't work at all. Do I understand from this discussion that partial failure--i.e. rough running--is a possibility? If so, it might explain a problem I am having that I can't find another explanation for.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
10-13-2020, 10:04 PM | #16 | |
10-13-2020, 10:12 PM | #17 | |
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
10-13-2020, 11:43 PM | #18 |
On the Team Chevelle forum there is a guy who worked for gm and helped develop the HEI. This is what he always says modules usually don't just fail. From his info, almost all module failures are from coils starting to fail, overloading the module.
http://67-72chevytrucks.com/vboard/s...d.php?t=698292 |
10-14-2020, 05:55 AM | #19 |
Actually, I take my prior comment back. The first HEI I ever had I installed in a '71 K/20. I bought a rebuilt GM unit. One day I shut the truck off to load and when I went to start it only cranked, no spark. I replaced the module and about a week later, same thing. Upon closer inspection I discovered both wire from base to coil have tiny breaks in them, I could see patina green copper. I had a '77 parts truck sitting there, stole that wiring off it, put it on the '71, and it ran for many years without an issue. That HEI is powerful and sensitive. I did smear it up real good both times
10-14-2020, 06:53 AM | #20 |
Post Whore
I can add that my Burban was running fine. I had been on freeway for 15 minutes and had exited and had traveled about 5 more miles at 40 MPH with several stop lights.
The engine gave no warning, it just died. When I tried to restart it it would only pop once every 5th or so revolutions. When I got the module out it was very hot. To hot to hold. There was a white heat transfer compound under it. Also the HEI in the Burban was an aftermarket unit.
10-14-2020, 07:44 AM | #21 | |
1969 C-10 Supercharged 355 12.20@104 1968 Firebird Nat.Asp. 355 12.50@106 2002 GMC 2500HD Duramax 13.0@104 |
10-14-2020, 07:49 AM | #22 | |
10-14-2020, 07:55 AM | #23 |
I thought it might have been mis-construed as it would be easy to assume it was the ignition coil. This is what is looks like typically. Good Luck partner.
10-14-2020, 07:57 AM | #24 |
Just so we’re all looking at the same thing here. It does look like you’re talking about the pickup coil.
10-14-2020, 09:03 AM | #25 |
Alright.. pic didn't load. Here we go again! This diagram shows it as a "pole piece."
