Old 10-17-2020, 12:09 AM   #1
suburban99
suburban99's Avatar
35" KO2's on a 72 K10..what pressure do you run?
Just wondering what tire pressure to run in my 35 x 12.5 KO2's..
Currently running 26 PSI and they look crowned. When I pull into my shop the concrete dust covers about 10" of the 12.5 width. Whatcha running in yours?
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
Old 10-17-2020, 09:30 AM   #2
sweetk30
sweetk30's Avatar
Re: 35" KO2's on a 72 K10..what pressure do you run?
sounds good via the dust cover . you want about 3/4 coverage .
my old 38" bias swampers i run 25 psi and had good wear and ride .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-19-2020, 09:45 PM   #3
Mike C
Mike C's Avatar
I run the 35" AT's on my Jimmy at 24 psi.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-24-2020, 10:55 AM   #4
57taskforce
All about them K’s
57taskforce's Avatar
25lbs here for my 35” Mickey atz’s
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 10-28-2020, 06:59 AM   #5
4u2nv
i'm going to have to look at mine and see what it recommends for psi
I'm running 36 psi for every day use .
4u2nv is offline   Reply With Quote
