10-17-2020, 11:49 PM | #1 |
California certified 6.2 diesel? Gas to diesel swap
I'm waiting for a call from the smog ref,but I'm thinking that if a "California certified"6.2 diesel exsists,i can do the swap I want to do.can anybody confirm if there was such a thing as a California certified 6.2 diesel?
And does anybody know which would produce more emissions? 454 gas engine or the 6.2 diesel? |
10-18-2020, 03:29 PM | #2 |
Re: California certified 6.2 diesel? Gas to diesel swap
What year truck is the engine going into and what year vehicle is the engine coming from?
10-18-2020, 05:56 PM | #3 |
You can swap in a cummins, a brand F IDI, and the 6.2.
They just need to be vehicle certified, and not generator or industrial engines. I don't believe there was a CA version of diesels at that time since buyers were into gas engines. I am not Mr. Diesel here, but my research says it is not much more difficult to get a Cummins 6BT into the truck smog legal then the 6.2. Plus you'll have a engine that will increase your value of the truck. Plus in reality it is not much more expensive the a 6.2 swap. Last edited by Ziegelsteinfaust; 10-18-2020 at 06:25 PM. |
10-18-2020, 07:00 PM | #4 |
My truck is an 82 and the engine is from an 83 both trucks are 1 ton crewcabs.i did some more digging and found that the engine I want to use is a California engine.(said it right on the air cleaner)
10-18-2020, 07:07 PM | #5 | |
I'd love to do all that,but I gotta work with what I have.according to the smog bar requirements it has to be an engine that was offered in the truck and in the same weight class.im thinking I will be able to meet all the requirements for the swap.im wondering if I'm missing something or reading something wrong. Or if anyone has done this swap recently.the threads I've read about it are over 10 years old and I know alot can change in that time. |
10-18-2020, 08:52 PM | #6 |
Both those engines were offered in the same weight class. 3/4, and 1 ton trucks.
So they are legal you just have to swap the emissions stuff over too. Just like the 6.2 diesel. Which is why you can not use industrial grade or versions. |
10-18-2020, 10:55 PM | #7 |
Thanks.im having a little more confidence about this now.but I will let you know what the smog ref says if he calls.
10-18-2020, 11:15 PM | #8 |
There's lots of good info out there on the swaps.
But from what I have learned is it is usually best to talk to the refs to really nail down what they look for. Plus make it look clean. Alot of it has to do if it looks right itnprobably is. |
10-19-2020, 12:11 AM | #9 | |
For sure.ill clean it up good but will probably leave the air cleaner alone.that has the California tag on it. |
10-19-2020, 10:26 AM | #10 |
It looks like you shouldn't have an issue. If you don't hear back from the referee, call your local BAR office. There are several around the state. They should be able to give you the correct info too. Here's the # for the Culver City office, (310) 410-0024. This is the list of the local offices statewide, https://www.bar.ca.gov/About_BAR/Contact_Us.aspx
10-19-2020, 10:53 AM | #11 | |
(The reason I'm looking for assurance here is because the lady on the phone said you cant change to a smaller displacement engine.but I think she was mistaken and meant you cant put a engine from a smaller weight class in.so I asked her if she knows of any exceptions to that rule and she said she really doesn't know.so thats why she made me an appointment to speak with a ref) |
10-19-2020, 01:41 PM | #12 | ||
Basically, the engine and all accessories need to look like they belong down there, and everything should look well taken care of. So it doesn't have to look like a concours-correct restoration, but it should look like grandpa's one-owner truck that's been dealer maintained. Not cobbled together by a shady car dealer trying to make a fast buck.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
10-19-2020, 02:15 PM | #13 | |
I have all the factory stuff.i got almost 2 engines.1 pretty complete and the other in pieces.im hoping to make one work from the 2. It will look cleaner than the half assed butchered engine stand for sure. |
10-19-2020, 06:58 PM | #14 |
Smog ref just called.IM GOOD TO GO!!
so happy about this. |
10-19-2020, 10:01 PM | #15 |
Excellent
