10-19-2020, 02:27 PM | #1 |
heater hose Grommet
I want 1 large grommet for firewall, all 4, A/C and heater hose go threw one grommet in firewall?
I see this on Iron Resurrection |
10-19-2020, 09:59 PM | #2 |
Re: heater hose Grommet
Are you meaning something like this? https://www.vintageair.com/hose-kits...-Way%20Diamond
10-19-2020, 10:00 PM | #3 |
10-19-2020, 10:15 PM | #4 |
10-20-2020, 07:05 PM | #5 |
That isn't going to work with multiple hoses It's for just as it shows in the add, putting around one larger pipe.
Here is another link with multiple options for bulkhead fittings http://www.tbiproducts.com/index.cfm...e=cat/cat8.htm
10-20-2020, 07:48 PM | #6 |
mr48 Yes I have a 4 way bulkhead AN threaded that I will not be using.
It needs 8 fittings just for that fitting, I will not be using worm hose clamps either. It's going to be hard enough to hook up all the line to the A/C unit under that dash. It's not going to be perfect but it's going to look Awesome |
10-20-2020, 09:29 PM | #7 |
You would probably better off to take a sheet of rubber about 3/8 inch thick cut in a circle large enough to run the four hoses though, punch correct size holes for each hose in the pattern you want and use something like a ring off a shifter boot or your own ring to hold it in place.
