10-21-2020, 03:40 AM | #1 |
1974-454 What "Mark" do I have?
Wikipedia lists BBC stats and GM product designations for passenger cars but I can't find a product code for those used in half ton trucks, specifically the 454 used in the C10 from 1974.
I know it's a low HP engine but what do I look for when researching bolt ons like better heads, cam, intake? I'm entertaining the idea of a small cam but IIRC any increased lift while running peanut heads may be a problem. In short: What bolt ons can I add to wake it up?
Repairing and driving old trucks is an analog experience. No computers or sensors and they can be fixed with basic hand tools |
10-21-2020, 04:13 AM | #2 |
Re: 1974-454 What "Mark" do I have?
The Mark IV is what we think of as the big block after the W-head engines ~65/66 and up to about 90.
10-21-2020, 07:48 AM | #3 |
If it's from a 74 good chances it has 049 or 781s, those are best heads you could get for a street motor, AKA junkyard heads. I had each, last one was over 400 horse easy. I wouldn't worry too much bout putting in a bigger cam with whatever head, use matching springs and run it.
10-21-2020, 11:04 AM | #4 |
Waking up a 74 big block is easy. Bump the compression to no more than 9-1 and put in a mild cam. stock heads are fine unless you plan on reving it more than 5k. Doing those 2 things will almost double the HP from the factory
10-21-2020, 01:12 PM | #5 | |
Moderator
The block should have a stamped number on the front of the passenger side head, might tell you more. Hagerty shows a 454 in a 2 door stepside longbed for that year though so who knows? You could go to the GM Heritage Center and download the 1974 Chevrolet Trucks booklet to find out - https://www.gmheritagecenter.com/gm-...tion-kits.html It shows on page 23 of that PDF document that the C10 had a 454 option code #LF8. With a whopping 230HP advertised.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 10-21-2020 at 01:27 PM. |
10-22-2020, 02:54 AM | #6 |
Thanks to everyone for the info. It's exactly what I was after.
B454RAT: If I read correctly you were using peanut heads when you got 400HP. What all did you do to get that number?
10-22-2020, 11:28 AM | #7 |
10:1, ran 93, 781 heads, comp came extreme energy 268, dual plane intake Holley 3310 750, used manifolds cause trying to fit headers n a G body with 4-speed was tough. Never got the motor 100% dialed in but ran like a mother f’r. Regret selling it.....
10-22-2020, 12:42 PM | #8 |
driving is in my blood
No, he had oval port heads like any 454 from 1974 should have including yours. Peanut ports were 80's.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
10-22-2020, 01:02 PM | #9 |
Other than tall deck was even any peanut ports used? Most of what Ive seen were 049 n 781s.
10-23-2020, 03:06 AM | #10 | |
I see some some upgrades in my future.
10-23-2020, 08:22 AM | #11 | |
346236.....75-87...oval...OPEN...454, 120cc chamber, 225/116cc ports. So if that was a late 1974, it could have peanut ports, which IMO isn't a bad thing |
10-23-2020, 09:56 AM | #12 |
Only reference to peanut ports I’ve found is a 1986 casting.
Post your head casting numbers. That’ll clear it up. |
