10-25-2020, 07:57 PM | #1 |
Look at what I found.. Need to replace..
Doing a 402/700r swap into this 72 blazer.. While everything is out and getting cleaned I figured I would drop the TC and give it a seal kit and clean it up..
It appears someone had a problem years ago.. It has been driven like this for a very long time but I just cannot see letting it stay, any opinions on that? I figured I would just replace it, should I go with advanced adapters or should I try and find a oem adapter? Thoughts? |
10-25-2020, 08:46 PM | #2 |
Re: Look at what I found.. Need to replace..
It's not the prettiest, but it looks like a solid weld, and as you said, it's been driven like that for years.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
10-25-2020, 09:11 PM | #3 |
Carpe manana
Moved thread with hopeful intent you’ll get more responses here.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
10-25-2020, 10:01 PM | #4 |
All about them K’s
If it was me I’d get a new one personally. The 50 year old oe piece is a crapshoot at best. They are notorious for cracking out. I’ve always heard removing the side mount front e transfer case helps to remedy the problem. My K20 has the side mount removed with no issues.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
10-25-2020, 10:18 PM | #5 | |
So your just running with the adapter mount and it floating otherwise? |
10-26-2020, 08:13 AM | #6 |
All about them K’s
That is correct, transfer case bolted to the crossmember only.
10-26-2020, 12:08 PM | #7 |
Looks like it's brazed. Probably got the leak sealed though. Anyhow, new aluminum from Advanced adapters are probably only a couple hundred bucks, and they claim much stronger than original. Only thing to ask is the thread size for the shoulder bolt for the transfer shift lever. You may have to get a new pivot/shoulder bolt as well. Use the correct specified gasket and not RTV to seal when assembling(just in case you didn't already know).
j
White K20 |
