10-25-2020, 11:17 PM | #1 |
Engine running too cool
Hi all,
I have a MarkIV 454 in my ‘68 K10. It has a 180* thermostat, cheap 2 core radiator, and 2 temperature sending units on the back of the intake manifold. Now that the weather has cooled way off, I’ve noticed that the engine temp is dropping down to 140-150* at highway speeds. If the truck is just idling in park it will warm up to 180+ but it takes a very long time. I don’t believe it’s a sending unit issue because both gauges read within 5* of each other at all times. I’m guessing the thermostat is stuck open, but before I go through the hassle of ripping into and replacing the thermostat I wanted a second opinion. Thoughts?
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296 |
10-26-2020, 12:37 AM | #2 |
20' Daredevil (Ret)
Re: Engine running too cool
My guess is same as yours -- t-stat stuck open. Check the specs for that engine though, I suspect a 180* might be too cool. A 190* or better yet a 195* might be a better choice, especially in Michigan in winter. And it won't make your engine overheat in summer.
10-26-2020, 12:38 AM | #3 |
It can also be your electric fan on to much as well as a stuck tsat
my trucks only get a 195 stat year around Last edited by gmc684x4; 10-26-2020 at 12:49 AM. |
10-26-2020, 09:27 AM | #4 |
180 Deg stat was the norm for years. Then it was raised to reduce emissions.
10-26-2020, 09:41 AM | #5 |
If you have two temperature sending units in the back of the intake are you sure you’re not running way hotter than what your gauge says.
10-26-2020, 09:51 AM | #6 |
I agree . I have all the mechanical sensors in the head , temps can be 20 to 30 degrees hotter in the head . My Chevelle reads 205 when the electric fans kick in they are Controlled by a sensor in the radiator that kicks on the fans at 195 water temp .
10-26-2020, 08:46 PM | #7 |
Where is the stock sending unit location? If I understand the cooling system correctly, there shouldn’t be any coolant flowing through the upper radiator hose until the thermostat has opened. So if the thermostat is stuck open and I start the truck after it’s been sitting all night, I should feel coolant moving through the upper radiator hose, right?
10-27-2020, 12:03 AM | #8 | |
The Older Generation
Driver side head by #1 plug. LockDoc
10-27-2020, 12:13 AM | #9 | |
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
10-27-2020, 10:37 PM | #10 |
Who Changed This?
That's on an SBC, right? Because my (70) BBC has the temp sender on the passenger's side, and the wiring appears to be stock.
10-27-2020, 11:33 PM | #11 | |
Yup, Brain fart on my part..... LockDoc
10-27-2020, 11:54 PM | #12 |
Who Changed This?
Well, I never noticed that the sender was on the driver's side on the SBC, so there you go. And to think that I worked on these things for many years. I worked for my BiL starting at age 15 ('67) on the weekends doing basic mechanical work. I know that they were all pretty much stock in those days, and we only fixed things, and didn't do anything custom.
10-28-2020, 09:00 AM | #13 |
Do a search Steve.
Some bbc had the temp sensor between #3 and #5. 69 L78 did. Factory valve covers had a clip on them to hold the wire for the sensor. The tall deck motors had it too. http://67-72chevytrucks.com/vboard/s...d.php?t=437017 Last edited by geezer#99; 10-28-2020 at 10:06 AM. |
