10-27-2020, 10:46 PM | #1 |
Electric steering
Anyone have experience with electric steering or geared assist? Need to move away from manual steering on my 67 C30.
10-27-2020, 11:05 PM | #2 |
Re: Electric steering
Why not dimple the frame and put power steering on it? I just put PS on my truck and I’ll never go back. There are plenty of threads on this board about how to do it.
1968 GMC C2500 Long Bed Fleetside |
10-27-2020, 11:55 PM | #3 |
To be er, kind, why buy an old vehicle, then convert it to what it isn't?
Sell it and buy a Prius. Or, learn to drive manual steering (different technique), lube the parts and enjoy... |
10-28-2020, 12:05 AM | #4 |
I would dimple the frame to use a standard ps box you can also look at power rack and pinion options as well
10-28-2020, 07:30 AM | #5 |
To some people, driving their truck is more about having a good time riding around town rather than sweating and having a hard time pulling into/out of a parking spot. If I was doing a restoration I wouldn’t have installed power steering, but I’d rather be able to hop in my truck and go for a ride. As someone on the forum once posted, the only reason no to install power steering is if you don’t want other people to drive your truck. After I installed power steering my wife has driven the truck, which I thought was really neat because maybe she’d start to understand why I spend so much time working on it (no luck)
10-28-2020, 08:49 AM | #6 |
My brother put Electric PS on his 61 Corvette it was quite pricey and a lot of work as you have to cut, modify reweld the column. Everything fit up under the dash out of sight.
It works but I would do as others say and dimple the frame for the factory system if you really want PS. |
10-28-2020, 09:02 AM | #7 |
Seems like I've seen someone offering a kit for electric power steering for C10s. Not sure about the C30. I've seen a thread on another forum where someone did this swap with a Cougar, and they seemed to really like the way it performs.
It would be interesting to see it done and get some feedback on how well it works in these trucks and under what conditions. So it really comes down to whether you're looking for the easiest way to get easier steering, or if you're wanting to try something new. Either way, it's your truck, so do what makes you happy. |
10-28-2020, 10:27 AM | #8 |
You could also find and install a 67-68 power assist system as well. You won't have to dimple the frame either, not that it's a big deal
72 C10 lwb fleetside -stock 350/350 combo |
10-28-2020, 10:28 AM | #9 | |
And to be "kind" it's his truck and can do what he wants to it ,so your comments aren't necessary.
10-28-2020, 10:32 AM | #10 |
This isn't a bad idea. I don't have experience with the ram assist system, but I think these systems are harder to find and aren't as readily available as the PS system. You can pull a PS system out of a squarebody in a junk yard and rebuild it yourself. I found a donor 71 frame and grabbed the whole front end (disc brakes, power steering, front crossmember, etc.) for $300 then rebuilt everything. I haven't looked back
10-28-2020, 10:44 AM | #11 |
Correct, they're not as plentiful as the later systems. They were used in a lot of different vehicles so they're still out there and not too hard to find. I would use one just to be different than everyone else.
10-28-2020, 11:44 AM | #12 |
Thanks for all the responses that have objective information. I appreciate those that see a different way of doing something. I now have some information with which to make an objective decision and a plan to have some fun tinkering with my truck. The technology is available why not use it. I do appreciate "The Ride" of an older truck and plan to maintain it.
The opinions of others are considered but the Prius comment was way out of line and insulting. Any other objective information is still appreciated. |
10-28-2020, 12:20 PM | #13 | |
j
White K20 |
10-28-2020, 04:41 PM | #14 |
I may be all wet but I think over on LS1tech.com or Pro Touring.com they use a Volvo? electric power steering pump to provide pressure to the power steering box. Don't have any details other than that. Might be worth a search.
10-28-2020, 09:30 PM | #15 |
10-28-2020, 11:12 PM | #16 |
Location: Herculaneum MO (20 minutes south of St. Louis
Really? My mother's 66 Chevy Biscayne had no power steering or power brakes. I never saw her struggle to park it wherever she needed and she was maybe 5ft 2in. If you are sweating from it that's just poor technique.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
10-29-2020, 12:22 AM | #17 | |
My comments, your comments, all other comments, as well as the original post are unnecessary. Was there a point to your comment? My point was learn to drive manual steering and it's fine. It isn't the same as PS. Or, more succinctly, lighten up Francis... |
10-29-2020, 01:06 AM | #18 |
Power assist uses this set up. Lots of models used this in the early 60s and every version has specific mounting brackets and hose lengths.
10-29-2020, 02:03 AM | #19 |
10-29-2020, 09:50 AM | #20 | |
10-29-2020, 10:00 AM | #21 | |
But back to the OP there are plenty of aftermarket systems . I personally dont like the feel of the ram type ps . 3 of my cars have this type and they are ok but tend to leak
10-29-2020, 10:24 AM | #22 |
I dont know why but 66 Chevelle has manual steering and it very easy to turn compared to my truck. Maybe geometry of the steering to suspension . It also has radials so that probably helps a bit
10-29-2020, 10:57 AM | #23 | |
For my part, even under the best circumstances, manual boxes are just no fun to drive if for no other reason than they're too many turns lock to lock. But everybody has different expectations for their trucks, so YMMV. |
10-29-2020, 02:41 PM | #24 | |
Post Whore
You may be interested in the link below. https://www.carthrottle.com/post/ele...-does-it-work/
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 10-29-2020 at 02:46 PM. |
10-29-2020, 04:55 PM | #25 | |
The link was good. I did not consider the "feel" aspect that is lost unless a complex system is put in place. I would also consider steer by wire but kinda suspect it would not be in my realm of possibilities. Infinity, Lincoln and others have "kits" but hard to find good info on what pertains to my reality. A TRUCK! Thanks |
