![]() Join Date: Jul 2008
Need some battery cable advice
I did an LS swap in my 69 C10, I used the truck motor, wiring and accessories along with the F body oil pan and drivers side battery location. Since I used the truck battery cables on the drivers side with the F body oil pan I can’t use the plastic battery cable clamp that mounts to the truck oil pan. Now the battery cables lay between the engine and draw bar and would like to secure them better.
What have you guys done to secure the battery cables using the Floyd oil pan?
1965 c/10 swb 1969 c/10 lwb ![]() |
Re: Need some battery cable advice
You can run battery cables any where you want really. I have an Fbody pan but I ran my battery in the rear of my truck and made new cables to run to the starter.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
Just looking for advice how the guys who run he f body oil pan and secure he truck style battery cables so they aren’t resting on the frame
i would use some clamps and run the oil pan bolt thru the clamp and secure it to the oil pan. i hope that idea helps.
