Ground the PCM
Went for my first start today with 5.3 swap homemade harness. Dead with no fuel pump kick on. I imagined the worst, did the harness myself with lt1swap instructions. Read on another sight to ground the pcm case. It fired right up
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Ground the PCM
Thanks for the insight.
Re: Ground the PCM
The PCM body doesn't need to be grounded......If it did, You're missing ground connection somewhere.
Re: Ground the PCM
I've never grounded the case of the PCM on my LS swaps. But I've never built a harness myself. Always purchased the PCM and harness from the same supplier.
Re: Ground the PCM
Now that I think of it, there were a few stray ground wires not accounted for, but grounding the case fixed it
Post Whore
![]() ![]() Join Date: May 2015
Re: Ground the PCM
With a LS swap, the more grounds the merrier...
![]() Join Date: Sep 2005
Re: Ground the PCM
I had to do the same thing on my swap about 300 miles into swap I had lot of run issuses turns out I never bolted the grounds to back of the head and they where touching hit a bump lost ground I felt like an idiot but never went back and ungrounded the pcm
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Re: Ground the PCM
As said above Ls swaps love good clean grounds. Main ground cable from the battery I run the 00 gauge cable directly to the engine block. Then on each side of the engine block back to the frame. Similar size cable. I try to hide them. If you have any paint on the block make sure you sand down to good metal. Star lock washers help bite into the head bolt holes.
#9 | |
BMW & ASE Master Certified
Re: Ground the PCM
if that's the case, your going to be creating problems thats going to be hard to trouble shoot over the web....
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
