10-31-2020, 09:56 AM | #1 |
laying low
safety chains and the laws
My cousin and family were nearly killed back in the 60s when a packed uhaul trailer came loose and crossed into his path. Head on impact.
I have always had safety chains on my trailers and never gave it much thought past it's good insurance. Until recently. I've been watching off road recoveries from out in Utah on utubes. I have seen Matt have his trailer come loose from his jeep twice now and no sign of safety chains. The 2nd time his trailer rolled down off the rocks and slammed into a big one just missing a new sxs at night time and people around. That could have been real bad. I got to looking for them in his other videos and have not seen them in use at all and I wonder is it not law in all states to use safety chains? Law or not, they can be a life saver.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
10-31-2020, 10:47 AM | #2 |
Who Changed This?
Re: safety chains and the laws
I have two safety chains on my trailer, and a safety trip wire that locks the trailer's brakes in case of a breakaway. I hope I never find out what happens if my trailer were to break loose.
10-31-2020, 10:49 AM | #3 |
Moderator
By state - https://www.rvia.org/system/files/me...equirement.pdf
https://drivinglaws.aaa.com/tag/trailer-hitch-signals/
10-31-2020, 11:19 AM | #4 |
U-Haul is supposed to cross the safety chains under the tongue so it can't hit the ground. That's how I do it with my own if the chain(s) allow for it. Probably the renter unhooked and then re-hooked the trailer without the chains.
When I hauled our MH from KS to CO it didn't have any safety chain, so I took one of my log chains and looped it around and through the A-frame and then hooked the two ends to the truck frame. Moving it five miles up and down the road spring and fall, I'm sure I didn't bother. Only once ever had a trailer come loose. It was a pintle hitch and that truck (not my GMC) just had two big plates with matching holes and a long pin that just dropped in. Running empty the pin bounced out and first thing I knew the trailer was swinging crazy just on the chains. I stopped and walked back and found the pin. After I gave that POS truck back and got my big GMC, I put a real latching pintle hitch on it but I still always hooked up the safety chains. Ball couplers really aren't that strong. They're designed just to keep the tongue from bouncing off the ball and mostly depend on hitch weight. One time I got the bright idea to use a ball and coupler for a hinge for a crane boom, and blew it out the first load that I put on it! I had to weld up a u-joint hinge from scratch instead. Matt is a great guy and I've learned a lot from his recovery videos, but lately I'm thinking that his "whatever works is okay" approach is going to cause major damage or injury someday. I've done a lot of things that worked once but I wouldn't try it like that again. I know he doesn't want to haul extra weight and doesn't want to sweat out in that heat, but most of those stranded vehicles I could get out with a hi-lift jack and a shovel. The jack would come in handy for getting those broken Razors on the trailer or at least getting them straight.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
10-31-2020, 11:30 AM | #5 |
Old member
I pull a 18' trailer a lot with my golf carts back and forth to the beach which is a 5 hr ride each way so I have safety chains and the brake release hooked up all the time.
From what my insurance said about the trailer is if I don't have them in use and they prove I don't use them then my insurance will not pay if it comes loose and hits somebody are damages property. I use them just like my seat belts.
10-31-2020, 11:52 AM | #6 |
laying low
A neighbor friend of mine hooked up to his ski boat to take a couple of blocks over to a guy to work on it for him and since it was just around the corner so to speak he didn't bother with the chains and guess what. The boat and trailer bounced up and the coupler rammed into the deck lid of his 65 GTO.
Places like uhaul all probably make sure rentals are hooked up proper at the time they are picked up but what a renter does after that is on them. What happened to my cousin and family is the guy coming the other way did not use the chains and the trailer came loose and came across the center line into my cousins lane and hit them head on. Apparently it wasn't coupled properly either. There was no time to react. I don't fear a trailer coming loose and slowing down in front of me, it's the one in the other lane that could come across at me suddenly.
10-31-2020, 12:17 PM | #7 |
Post Whore
I was thinking crossed chains was a law here in Ala...
But looking at Rods charts chain arnt even required.. I've pulled trailers 1000s of miles and only had one come unhooked.. it was a boat trailer that my buddy hooked to my 72 blazer...the trailer had a 2in hitch and he hooked it on my 1-7/8 ball...ain't nothing like looking at a trailer tounge in your back glass at 55mph.. I've also noticed noticed Matt's lack of chains...now that yall have me hooked on his videos from another post on here, I've been watching his vids...
10-31-2020, 12:44 PM | #8 | |
U-Haul hitches don't latch down; they have a screw tightener that has to be adjusted properly. People that pull trailers all the time aren't usually the problem; the ones that do it once it a great while often don't know what they are doing. BTW, always check the tire pressure and lug nuts if you rent a U-Haul trailer. Don't believe them when they say everything has been checked and it is fine. Also, every time I stop, I walk all the way around and visually inspect hitch and trailer, and I feel the hubs to make sure a bearing isn't getting hot (rental trailer or my own).
10-31-2020, 12:57 PM | #9 |
R.I.P. E.S.L.L.
I don't care about the law. I always run chains on my trailers. End of story.
I would never want to be the guy that harmed someone because I was too lazy to properly hook up my stuff.
1971 Custom C/20 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
10-31-2020, 01:17 PM | #10 |
laying low
Here is an interesting article on this subject.
https://mechanicalelements.com/trailer-safety-chains/
10-31-2020, 02:44 PM | #11 |
The only trailer that ever moved behind one of my trucks w/o chains never left my driveway. But I'm not sure if I've even done that. I don't need a law to force me to be smart. Why on earth would anyone haul a trailer w/o safety chains? Especially a towing and recovery guy??? That's just plain ignorant.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 10-31-2020 at 05:56 PM. |
10-31-2020, 02:52 PM | #12 |
Moderator
Exactly.
10-31-2020, 03:19 PM | #13 |
In answer to the question, yes, it is the law here in Utah. And it's just plain stupid to operate without them.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
10-31-2020, 03:56 PM | #14 | |
As I said before, I rigged up one of my log chains when I moved it long distance. After that until we sold it, the only place it went was back and forth just a few miles on a gravel road between our summer and winter parking place for a couple years. I sure don't remember messing with a chain for that little bit. Probably didn't go over 20-25 mph and don't know if we ever even met another vehicle since it was off season. Fifty foot trailer with probably 1500 pounds of hitch weight, wasn't going to bounce off. Sometimes we moved it with smoke still coming out of the wood stove chimney
10-31-2020, 04:05 PM | #15 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
10-31-2020, 06:02 PM | #16 | |
10-31-2020, 08:25 PM | #17 | |
As far as "something dumb" with trailers, that would be more along the lines of too heavy a trailer and too light of a pickup. That's why anymore I am a "never can have too much truck" sort of guy The trick to having lots of stories to tell is surviving those stories when they happen. Otherwise I guess you're part of someone else's story ...
10-31-2020, 08:58 PM | #18 |
Years ago, a bunch of us were going to lunch and were on the south bound part of I44 where it meets I40. A lane of traffic joins on both sides of the south bound highway. A single axle trailer crossed all four lanes and slammed into the bridge railing about fifty feet in front of us. It was still grinding to a stop as we passed. No clue which was the tow vehicle or if they even realized their trailer was missing. Sheer luck that it didn't cause a multi vehicle pile up.
Things like that make you a believer in chains and lock pins on the latch levers. |
10-31-2020, 09:04 PM | #19 |
Heard a story about a guy pulled over one night by the state patrol:
The trooper informed him that his tail lights were out. "Oh no!" the driver exclaims and jumps out and runs to the back of his car. "Oh my god, oh no," he cries. "Calm down, sir," the trooper says. "I'm just telling you so that you can get them fixed. I'm not going to give you a ticket." "But my boat! My trailer !!!!!"
10-31-2020, 11:08 PM | #20 |
Thinking back didn't U Hual have there own ball size ? like 2 1/8
11-01-2020, 04:20 AM | #21 |
No, they're stuff is 2". They did teach us to twist the safety chains to adjust the length.
11-01-2020, 12:59 PM | #22 |
Yeah, you used to have to rent (or buy) a ball from them. Plus if you already had trailer wiring you had to buy an adapter or else let them start chopping into your wires to put in their own little dangly plugs for each separate wire. I still have the adapter that I bought years ago but they don't use it anymore.
We rented a 6x12 in July 2020 and all that has changed. Two inch ball was fine; they said their coupler would crank down on any size (Huh?!). They had a flat-four plug to go right into my factory Silverado trailer wiring. There was a trailer system fuse out for my right signal/brake in my pickup and they traced that out and came up with a working fuse at no extra cost (this was the first time I towed something with my 2016 pickup so I guess I should have checked it out first!). I checked the trailer tires' pressure right there when they were hooking it up even though they said it was fine (this time they were correct). After I got it back to my mom's house, I checked the lug nuts and at least one wheel was not tight at all! They don't have hubcaps anymore; back years ago with my mom we pulled into a gas station with a 5x8 U-Haul and there were two or three lug nuts rolling around in the hubcap! I never unhitched/hitched the trailer not because I couldn't but we were on a schedule and I didn't have time to muck around with anything else. Four days only allowed to load, drive 700 miles, and unload, and then drive to a town to return the trailer. It was packed solid front to back and we had to integrate all this stuff into our household. So overall U-Haul is better than it used to be. They require you to have an adequate hitch now, instead of renting out those stupid hitches that clamped on the car bumper! They kept asking me what my hitch was rated for and I said it's a factory hitch and the pickup is rated to tow 14.5K Beware they require you to provide the phone number of a relative/friend who they call and must answer the phone Right Now or else they won't let you leave with the trailer or truck. And they don't tell you that when you reserve the trailer
11-01-2020, 01:10 PM | #23 |
Just another thought:
Are safety chains required on pintle hitches ??? I had chains on my army/log trailer and used them, but I don't know about Class 8 "pup" trailers for instance. I do know a truck lost a trailer into a coulee off the highway near us a few years ago.
11-01-2020, 01:29 PM | #24 |
That may be a local franchise rule. I've never had that happen. What I have had happen is that I have a confirmed reservation and then get bounced around from one location to another to another to actually find the trailer that was reserved at the first location.
11-01-2020, 02:25 PM | #25 | |
