11-05-2020, 11:47 PM | #1 |
Lift question 70 K10
Is it normal to have the rear axle/tire so close to the front on the wheel well when you put a 4 inch skyjacker lift on a SWB? I didn't think it looked right. Thanks for the input!
11-06-2020, 12:48 AM | #2 |
All about them K’s
Re: Lift question 70 K10
My ‘69 Swb K10 has a 4” rough country and the axle sits similar to that. I’ll see if I can find a comparison picture. The axles on these trucks aren’t perfectly centered from the factory and lifts seem to exaggerate this.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
11-06-2020, 03:31 AM | #3 |
That's what I thought from all the pictures I saw of other lifted short boxes online. I'm not crazy about the way it looks. The distance on the rear leaf spring from the center bolt to eye isn't symmetrical. Front to center pin is 24 1/4" and the back is about 25 1/2". I installed them according to the directions (longer end to the back) but am contemplating switching the springs around. That should move the axle back a little over an inch and lower it about the same (sits too high in back anyway). Thoughts about this?
11-06-2020, 09:38 AM | #4 |
Post Whore
The springs are engineered to control axle wrap and give the best ride possible. I believe that reversing the springs is going to adversely affect the spring performance. But check with the manufacturer to be sure.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-06-2020, 10:27 AM | #5 | |
All about them K’s
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 Last edited by 57taskforce; 11-06-2020 at 10:53 AM. |
11-06-2020, 11:05 AM | #6 |
Put in zero rates and move your axle back an inch or inch and a half. I use zero rates on the one inch. Why does the rear of your truck sit up so high? Is the rear on jacks? The front usually sits higher after a skyjacker lift. And it makes zero rates nice for leveling the trucks stance. I think zero rates add 1" maybe a bit less to height. Anyhow, you can move the axle back using zero rates.
j
White K20 |
11-06-2020, 11:34 AM | #7 | |
As for the height being off, I'm going to assemble the front clip and see how clearance looks for the front wheel wells. If it's good, i could take a leaf out of the back spring pack to bring the rear end down a little and if the front is too close, I could add the zero rates up front to match the rear. As most things when you start messing with one thing it affects a bunch of others. Thank you for the idea about the zero rates. I'll attach a pic of the perches I used. |
11-06-2020, 11:54 AM | #8 |
If the vehicle weight is on the truck in that pic, I'd say you got 6'' springs by accident judging by the arc
11-06-2020, 11:54 AM | #9 |
All about them K’s
I would definitely move them to the front set of holes (moving the axle back) I know what you mean about messing with one thing and causing the domino effect. So did you swap the ho 52 in before the 14 bolt? What’s the back story on this build? Original short bed? Seems like you’ve done a lot of work on it.
11-06-2020, 12:08 PM | #10 | |
Have fun! j
White K20 |
11-06-2020, 05:49 PM | #11 |
It is normal and designed that way. Look at any stock truck and it will be the same way. First pic in my thread it is evident. As the spring compresses it will flatten and grow in length The front of the spring is fixed and the spring is arched. Therefore the axle will move back as the spring gets longer. Having the front of the spring lower than the back somewhat offsets the movement and helps with anti squat.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
11-07-2020, 04:01 AM | #12 | |
Its a cut down long box that I've been working on for way too long (4-5 years) and got way too in depth in. It was just supposed to be built as a daily driver but ended up being a nut and bolt deal. Looking in hindsight, I should of probably just left it a long bed, as it would have been done years ago. I had the frame shortened 4-5 years ago but didn't swap in the 14 bolt until after the frame was powder coated and started reassembly. I just got time to assemble the bed this week, so it's been the first glimpse of how everything is lining up. Hope to have it painted by this summer and finally be on the road. |
11-07-2020, 11:08 AM | #13 |
All about them K’s
Looks like a really solid build, nice work! Now things make a little more sense. The end result will be worth the time and sweat. You might start a build thread over In the 4x4 section of you don’t already have one. It would be cool to keep tabs on what your up to with it.
11-07-2020, 02:29 PM | #14 |
When I first got my '69, I too noticed the rear axle seemed to be too far forward. I picked up a Tuff Country EZ Ride 4 inch lift and noticed the leaf spring pin was not centered between the front and rear eye of the spring. To help center the wheel, I put the longer side towards the front. It rides rather well and the pinion angle is good. The first pic below is after I installed 33s on the factory suspension. The second pic is after the TC lift was installed.
11-07-2020, 03:46 PM | #15 |
All about them K’s
As we already documented, it is normal. Here’s a side shot of my 69 factory short bed.
11-07-2020, 10:27 PM | #16 |
i always thought they were designed to be a little to the front because they were designed to be working trucks once theres some weight in them the compression moves the wheel back . i could be wrong though im no designer
