11-18-2020, 11:13 AM | #1 |
Quadrajet gettin' place, '81 k20
Can you recommend who/where to buy a quality rebuilt quadrajet carb for a '81 K20 350
Need to pass smog so has to be matching part number jetting, etc Im pressed for time so, R&R, I will rebuild my old one later. Usually some rebuilds redo the loose throttle plate shaft with bushings anyway I have a couple old old links Recommendations please...Thanks Again , The carb has to have the same jetting so I can pass emissions test
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
11-18-2020, 02:24 PM | #2 |
Re: Quadrajet gettin' place, '81 k20
location?
I have had a couple of quadrajets rebuilt here over the past 25 years with good results.. being in socal, I'm sure they can set you up right https://jetchip.com/contact/ ask for Johnnie his work is published in several articles and they catalog carbs outright at summit, jegs, etc. good luck!
I started out with nothing - and I still have most of it |
11-18-2020, 05:22 PM | #3 |
Quadrajet Power LLC would be my go to https://quadrajetpower.com/
I had mine rebuilt by them but they will either build one for you or may already have one ready for your application.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
11-18-2020, 05:24 PM | #4 |
Another option is SMI at www.smicarburetor.com. They rebuilt mine. nice work.
11-18-2020, 06:26 PM | #5 |
X2 for SMI
11-18-2020, 07:27 PM | #6 |
I got a numbers correct quadra jet with the center fuel inlet for a 76 c10 454. a hard carb to fine from Quadrajet Power LLC They do great work
11-18-2020, 09:26 PM | #7 |
Ill have to call that Texas place, https://quadrajetpower.com/ tomorrow
They show the biggest selection... My truck is a 81 k20 , but the engine manufacture date on the air filter housing is 1980 . My has the air choke..... which impossible to adjust so is works . It only works in below 40 or less weather Do the electric chokes work properly...?.... looks like it can be converted to 'lectric
11-18-2020, 10:46 PM | #8 |
Hey Guys... Here is a great Qjet right up by Lars Grimsurd
http://corvette-restoration.com/wp-c...arb_Tuning.pdf
11-19-2020, 12:12 PM | #9 |
I had to pass emmisions in CO a few years back and it was such a hassle. I took truck to a mechanic who barely looked at it and said rebuild carb. I said I did and he said I didnt do it right.......really you barely looked at it. I left there and never looked back. I bought a rebuilt carb from Rockauto and it failed emissions test worse then old carb I rebuilt, sent back to RA. I fooled around with old carb adjusting idle mixture screws using vacuum and tachometer, truck still failed. I was about to give up and send my carb in to be rebuilt to a professional. I am not knocking the professionals but for a stock 350 q-jet the 400-500 (that is on the low side of cost) was just to much for me to spend. Lucky for me I found the Restoring Rusty post and how he added a O2 sensor to dial in carb. Well I bought a AEM O2 wideband sensor for 180 from ebay. I had to pay another 30 for muffler shop to weld in O2 bung, so about 200 bucks total. The best investment I made in getting truck to pass emissions with my rebuilt carb. It took a little trial and error adjusting idle mixture screws but finally got air fuel to around 14:1 at idle and passed emissions.
79 Chevy 2wd BIG10 350 TH400 |
11-20-2020, 07:58 PM | #10 |
National Carburetors is another spot. I have one on order for an '85 C30 454.
http://www.nationalcarburetors.com/cat-chevytruck.html
11-21-2020, 12:25 AM | #11 |
I ordered an Autoline Carburetor from Rockauto for my 71' Monte Carlo, worked perfect. You can buy them almost anywhere, Autozone, Amazon, Ebay Etc. They guaranteed date code for application too.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
11-22-2020, 11:42 PM | #12 |
Forgot about rock auto. They have several rebuilders listed , is Autoline special?
11-23-2020, 11:35 PM | #13 |
I don't know if they are special, but when I purchased they advertise they build the carb to your application and date code as if it came from the factory that way. I needed it because my carb guy was 6 weeks out. Autoline was highly recommended by my other car groups. Mine worked perfect.
11-24-2020, 12:17 AM | #14 |
Emissions requirements on a 40 year old truck. That sounds horrible. Wish you didn't have to deal with that.
1982 K10 SWB 1987 V20 - Sold - Doh! |
