Rear axle measurement differences
I have a 70 LWB C-10.
How wide is the original axle on on my truck? I have a line on a rear axle from a 2000 Silverado, that has the the Disc Brake setup on it. Now, I know the Spring perches and Shock mounts need to be moved. I was wondering if anyone can tell me the width of this axle, and will it fit my truck? It sure would be nice to have the disc brakes on the rear. ![]() |
All about them K’s
![]() Join Date: Jun 2014
Re: Rear axle measurement differences
It’s likely a good bit wider, I’m in the process of converting an old style 14 bolt to disks using late model 14 bolt brake parts as we speak. The single wheel 14 bolt has a 67” wms, if I remember right the newer 14 bolt is like 68-69”. I haven’t messed with the 1/2 ton stuff to know for sure though.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
My understanding 73 87 same width c10 gmt400 was a bit wider and gmt800 was even wider still
Thanks for the feedback.
I was kinda hoping to be able to do a simple swap, without a huge outlay of money, but now don’t think that’s gonna happen. I might draw up and fabricate a rear disc conversion setup, that’ll work with a stock rear end. Ok, it’s off to the drawing board ![]() |
Look up captain fab he has brackets for sale on the board that should fit your 12 bolt
http://67-72chevytrucks.com/vboard/s...d.php?t=711318 |
NO WAY!
Thanks for the lead! Now here’s the “Million Dollar”question. Is it possible to get the rotors that fit a SIX BOLT pattern axle? Last edited by custom10nut; 11-30-2020 at 01:28 PM. |
