Old 11-29-2020, 11:29 PM   #1
65chevysub
65chevysub's Avatar
Replacement Grilles
I have an 84 Sierra with the single headlights, that needs a new grille, and I'd like to know if I can use an aftermarket grille that says it's for the dual headlight setup? Do the Grilles all use the same mounts? Someone told me the core supports were all different.....
65chevysub is offline   Reply With Quote
Old 11-30-2020, 09:07 AM   #2
Re: Replacement Grilles
Should work just fine. The inner, or main grill is the same size. the outer covers for the headlights or headlight/turn signal combo differs. I have an 84 single headlight front clip setup on my 81 and iHave swapped the grills from several different years and aftermarket in it.
Old 11-30-2020, 03:31 PM   #3
65chevysub
65chevysub's Avatar
That's what I thought but wanted to make sure.
