12-05-2020, 05:42 PM | #1 |
Wheels backspacing
I was thinking about buying these wheels for my 72. I have 15x8 Ralleys now. The backspace on these new 15x8 wheels, is 3.75 Do you think these would work good on a 72. Thanks https://www.summitracing.com/parts/uwc-50-5873k
http://67-72chevytrucks.com/vboard/s...d.php?t=698292 |
12-05-2020, 08:20 PM | #2 | |
Re: Wheels backspacing
When you go to that aluminum wheel, you may need to change out your studs for longer ones because the thickness of the mounting surface on aluminum wheels typically is greater. |
12-07-2020, 08:24 PM | #3 |
I tried to use some mockup mags on my truck. Couldn't mount them because the studs were to short. So I'm now in the process of finding some longer studs.
The studs replacing are 1 1/2" from the bottom of the head. Looking for some 2" long from the bottom of the head.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
12-07-2020, 09:15 PM | #4 | |
Long shank lug nuts are available. |
12-07-2020, 11:53 PM | #5 |
laying low
Your 8" truck ralleys should have 4 1/4" back space so picture them 1/2" further out toward the edge of the fender for comparison.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
12-08-2020, 12:23 AM | #6 |
Geezer,
I'm using the rims off my 2012 jeep until I find some I like. Currently the stud is to short and lug would only engage about three threads.
12-08-2020, 09:26 PM | #7 |
That helps. Thanks
