#1 | |
1984-87 hydraulic clutch and manifold interference
I posted this to the LS-swapped squarebody group on Facebook. I'm double posting it here so it can be found by internet searches.
Feel free to post your own successes and failures in clearing the sm465 slave cylinder, either with manifolds or with headers. Quote:
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! Last edited by kipps; 12-17-2020 at 06:57 PM. |
Moderator
![]() Join Date: Jun 2017
Re: 1984-87 hydraulic clutch and manifold interference
Have you considered using a fully internal hydraulic release setup....and it opens up your choice for exhaust manifolds.
Speedway motors has a bearing set and its a reasonably easy install.... Hint....extend the bleeder pipe to make bleeding the system easier... See youtube https://www.youtube.com/watch?v=LInO0DnnhDw Speedway Motors link https://www.speedwaymotors.com/Chevy...SABEgLuJfD_BwE
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
#3 | |
I'm just posting these pics because this is a pretty common question by LS swap newbies. If you have the part numbers and/or pics showing how to retrofit an internal slave into a typical sm465 setup, please post them! That's completely in keeping with the theme of this thread. I want any and all reasonable options mentioned for folks who want to keep their sm465 behind a LS engine.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! Last edited by kipps; 12-17-2020 at 07:39 PM. |
