12-18-2020, 11:19 PM | #1 |
Stock Steel Wheels
Ok!! So I know this is an old topic, but I still need to ask simply because I havent found a concrete answer.
I have a 68 C10 current equipped with all drum brakes. Also, I have the stock 15 6-lug wheels that came with the truck along with the original hubcaps. My goal is to put a good set of disc brakes on the front and rear. However, I want to keep my original wheels or something similar so I can keep my hubcaps. Here is what I know. I know that the pre-71 wheels are 3 bump and dont work with any disc brake conversion. Post-71 wheels are 4 bump and could work with certain conversion kits. Any help is greatly appreciated. |
12-19-2020, 12:05 AM | #2 |
Re: Stock Steel Wheels
Your are correct, you need the four bump. Square body 4x4s had them, too.
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
12-19-2020, 07:56 AM | #3 |
Proprietor of Dale's Corner
X2,
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
12-19-2020, 08:13 AM | #4 |
Ok, I am lost but I have been lost before. His stock 15 inch wheels are 3 bumps so the stock hubcaps fit the 68 wheels. Are you guys saying that he needs post 71 4 bump wheels to go to disc brakes and his hubcaps will also fit?
Anyway, you may be able to use the wheels you have with just a 1 inch spacer. Maybe not. And maybe keep the drums on the back for the good emergency brake you have now.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 12-19-2020 at 08:16 AM. Reason: words |
12-19-2020, 10:03 AM | #5 |
yes, the 71+ K5/10 wheels, which can be quickly identified by the presence of 4 nubs, fit the pre-71 6 lug C/K10 pattern and will also retain the same caps that a 3 nub wheel will retain. The 71+ wheels have a different inner profile that clears a stock size caliper. If you retain the 3 nub on the rear, that's fine, but would be important to ensure your spare is a 4 nub so it will work if you have a flat in the front.
12-19-2020, 05:05 PM | #6 |
Awesome... Thanks so much for the information.
12-19-2020, 08:17 PM | #7 |
Roto Reuter thats the name...
If you need pictures let me know. I have 3-sets of these wheels. They are the 71-87 15X8 6-lug steel rims with 4-hubcap nubs. These are the steel wheels that can be used with disc brakes and still take the 10-1/8" hubcap. The '84 - '86 CUCV military Blazers came with those wheels too.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 Last edited by derotoreut; 03-12-2021 at 08:33 PM. Reason: Removed sentence referencing possible sale |
03-11-2021, 09:30 PM | #8 |
Junior Member
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. Last edited by LockDoc; 03-11-2021 at 09:59 PM. Reason: WTB by Non-Premium member |
03-11-2021, 09:35 PM | #9 |
BlahBlahBlah
Put a set in the for sale area if you want to sell them. This isnt the sales part of the board, and make sure you put a price on them.
03-12-2021, 02:00 AM | #10 |
The optional 16” wheels with 3 nubs will also fit. They’re harder to find, but just in case you stumble upon a set, they will work with disc brakes and hubcaps.
1972 SWB K10 1953 3100 1950 3100 |
