12-22-2020, 12:53 AM | #1 |
‘70 C10 with LM7/LS brake booster
Howdy,
I’m implanting an LS truck 5.3 into my ‘70. Will a stock sized 11” brake booster m/c setup clear the valve covers on the LS? Or is an 8/9” dual a better (but more expensive) option. What have you guys found in the past? Thanks. |
12-22-2020, 09:27 PM | #2 |
Re: ‘70 C10 with LM7/LS brake booster
The stock brake booster clears the LS without an issue.
12-22-2020, 11:14 PM | #3 |
Do you happen to have a photo? Or a link to one? Thanks.
12-23-2020, 11:06 PM | #4 |
60-66 Nut
If you do not currently have power brakes, this is an option.
http://www.67-72chevytrucks.com/vboa...d.php?t=347484 With my booster bracket you have choices of many, many, many compatible vacuum boosters as well as a hydroboost.
