Old 01-02-2021, 05:49 PM   #1
Steve Cole
What is this connector called?
Name:  coil harness plug.jpg
This is for the coil harness. The swap harness i bought is from BP-Automotive and two of the wires are in the wrong slot. I am getting a PO351 fault code (Ignition Coil 1 Control Circuit) and during trouble shooting I discovered the pink and purple wires are swapped with each other! I need to de-pin the plug on the BP-Automotive side and put the wires in the correct location but since I don't know what the connectors are called, I don't know what tool to get. Can someone tell me what tool i need to remove the wires from the plug?
Thanks!
Steve Cole is offline   Reply With Quote
Old 01-02-2021, 06:02 PM   #2
Thealien
Thealien's Avatar
Re: What is this connector called?
I am just guessing here, use my advise at your own risk. There is a grey clip or whatever its called on the back. I would try to get that off, shouldn't be too hard to figure out. Behind that there is most likely a wedge or something that locks the pins in place. Should be able to see how to get them out from there. I can usually figure a connector out. But I have broken a couple!
Old 01-02-2021, 07:54 PM   #3
ls1nova71
ls1nova71's Avatar
On the face of the connector you will see a smallhole/opening at the top of the connector terminal. You just put something small enough and strong enough to press the release on the terminal. A straight pin will work if its small enough. In this pic I'm using bailing wire sanded to a point on a sander. Dowsnt take much to release the tang.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-02-2021, 10:14 PM   #4
bigmoe
bigmoe's Avatar
A slotted jeweler's screwdriver or a dental pick works well if you've got one.
bigmoe is offline   Reply With Quote
Old 01-03-2021, 08:33 AM   #5
nsb29
nsb29's Avatar
I had the same problem with my light switch wiring from AAW
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 01-03-2021, 12:05 PM   #6
jjzepplin
jjzepplin's Avatar
I use a very small jewelers or watch type screwdriver. A small set goes a long way. Something like these. https://www.ebay.com/itm/6-pc-Jewele...gAAOSw9N1VvlHX
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 01-04-2021, 10:59 AM   #7
71cadc10
71cadc10's Avatar
I was gonna post pics, but see ls1nova already did.
note to first remove the rear cover, that retains the seals
gently push forward on the terminal you want to remove, insert pic tool to deflect tang, then pull out
the male side removes in a similar manner
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 01-04-2021, 01:21 PM   #8
Steve Cole
Thanks for all the help guys, got the pins swapped and put in the correct location. Engine runs a lot better now that all 8 cylinders are firing!
