01-03-2021, 03:20 AM | #1 |
1972 Doors, How to tell?
I have a 70 Blazer and I believe someone if the past has put on 1972 doors.
How is the ways to tell? I do have the Support screw under the Wing Window. Is the door jam different where the Latch bolts in? Thank you all. |
01-03-2021, 08:00 AM | #2 |
Proprietor of Dale's Corner
Re: 1972 Doors, How to tell?
If it has the screw under the wing window, it's a 72 door...
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
01-03-2021, 08:29 AM | #3 |
Equal opportunity joke ofender
There are 2 different versions of the vent window screw. 72 is a stamped recess in the door and the screw is recessed. 72 will also have plastic door panels that use longer shafts on the window & door cranks, unless someone put the 68-71 style cranks back in it.
70-71 just had a hole drilled in the door that had a hard plastic plug that sticks out higher than the plain of the door with a screw in the middle of it. they also have the shorter shafts since they use the metal door panels. here is a pic of a 72 only. I could not locate one for the 71 that I had .
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
01-03-2021, 08:35 AM | #4 |
here is what a 70-71 should look like. Pic borrowed from the board
01-03-2021, 09:54 AM | #5 |
Carpe manana
Can you post photos of your doors? Do you have plates around the latches like shown on this borrowed photo?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
01-03-2021, 10:37 PM | #6 |
my door just has a small hole for the screw, not a indention.
01-03-2021, 10:39 PM | #7 |
01-03-2021, 11:29 PM | #8 |
Scroll down to Manage Attachments and click on that button. It will open a new window (you may have to enable popups). Click on Browse and find your selected file. Then click Upload. Repeat the process for additional pictures. Then close the window and submit your post.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
01-04-2021, 08:13 AM | #9 | ||
https://67-72chevytrucks.com/vboard/...support+screws Richard
01-04-2021, 08:15 AM | #10 |
Here is a good step by step for posting pics
https://67-72chevytrucks.com/vboard/...d.php?t=712252 Richard
