01-05-2021, 10:47 AM | #1 |
Vintage air heater w/ defrost install
I installed this last year and thought I would share. The factory heater box was too large for my engine package and I have been driving around the last several years without heat which wasn't too big of a deal but not having defrost was the issue.
I bought this general purpose unit from vintage air p/n 506101 The nice thing about it is that the blend door and the coolant valve are electronic. The unit requires one 12v tap in (I used the factory fan wire) and everything else has it's own supplied wiring harness. I believe it is made in USA and was around $250. My only complaint is that the low speed fan setting is still very high and noisy. I may try to slow it down in the future but for now it seems to do a good job.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
01-05-2021, 10:51 AM | #2 |
Re: Vintage air heater w/ defrost install
The box tucks nicely out of sight.
While I was at it I had to relocate a couple gauges that were previously where the heater control is now.
01-05-2021, 12:10 PM | #3 |
How large are the controls? could they be installed in the ashtray opening? could you a picture of the firewall where the blower motor was?
01-05-2021, 12:22 PM | #4 |
I can't take any measurements as my truck is in storage at the moment. Here is a picture of the controls to give a better perspective.
The aluminum plate in the above pictures is where the factory box/blower motor was previously.
01-05-2021, 02:13 PM | #5 |
That is an impressive price. What is the thing that is mounted where the original blower motor was located?
01-05-2021, 03:01 PM | #6 |
It's a round disc that got RTV'd around the hole. There is a guy on ebay that sells the aluminum block off plate and blower cover for a bunch of different vehicles. They are around $40 bucks or something
01-05-2021, 03:52 PM | #7 | |
Looks good! I used the same unit in my 70 30 with the cummins for the same reasons.
here is the back of the controls. 20201222_210827 by jarrod vanwinkle, on Flickr I milled out a factory heater control that I picked up on ebay 20201211_214440_001 by jarrod vanwinkle, on Flickr 20201226_151931 by jarrod vanwinkle, on Flickr Here is is installed under the ashtray you can see it is small enough to be mounted in the ashtray opening if you wanted to put something else in the factory heater control place. 20201226_211056 by jarrod vanwinkle, on Flickr I did the same thing with the opening I found a guy selling 7" inch Aluminum Disc 2mm Thick on ebay it was like 12 shipped. I used seam sealer and 3 self tapers. 20201102_195332 by jarrod vanwinkle, on Flickr Last edited by jarrodblake; 01-05-2021 at 04:03 PM. |
01-05-2021, 05:09 PM | #8 |
I like the idea of using the factory heater control frame, that looks good.
01-05-2021, 07:32 PM | #9 |
J_cst_10,
Wondering how the routing of the vent and defrost hoses works out. Looks like it has two outlets, did you run defrost and lower outlets? Thanks in advance, Roger
1971 K10 short bed step side, 5.3/th350/205, 3.73 gears |
01-05-2021, 08:34 PM | #10 |
So the two outlets are for both defrost vents. There is a door flapper below that is hard to see. It has the option for defrost only - door closed, floor only -fully open, or blended.
01-05-2021, 08:52 PM | #11 |
Perfect, thank you.
12-30-2021, 07:46 PM | #12 |
Just Wondering when you wired this up if you went straight to the battery or to a keyed ignition source for power?
12-31-2021, 03:46 AM | #13 | |
20211231_023922 by jarrod vanwinkle, on Flickr |
12-31-2021, 10:56 AM | #14 | |
Posted via Mobile Device |
12-31-2021, 12:09 PM | #15 |
I did the same as well. That way you still use the fuse in the panel for it and it's goes on and off with the ignition key.
My only beef with the system after having it in service for a couple years is the blower motor noise. It is smaller and spins much faster then the factory blower which was huge and moves big volume at low speed. That being said I really only use it for the defrost function so I can see when it's cold and rainy. It works well for this so all is good.
