01-05-2021, 11:31 AM | #1 |
Junior Member
700r problems with reverse
I have an 82 C10 w/ a 350 crate and 700r trans. The PO did a frame off build roughly 6 years ago. The odometer currently reads 55k (I've put roughly 10k on it) but I have no idea if the odometer was set to zero at the rebuild. Also, I do not know if the tranny was rebuilt or how many miles were on it before being installed in this truck.
Started my truck this morning (daily driver) to let it warm up, as I do every morning. I put it in reverse and nothing. It works in drive and the lower gears. I tried reverse again, went 6" and stopped. Restarted the car, tried reverse again, it started to go back but the tranny acted as if the engine was stalling (if that makes sense). I put it back in drive, and it did the same thing, not smoothly moving forward. Prior to this I've had no problem with shifting gears or the tranny making odd noises or acting strange at all. It was cool here in south Florida this morning but was colder a few weeks ago and did not have this issue. I know I will be taking this to a shop but just looking for some insight of what I MAY be looking at ahead. Thank you in advance |
01-05-2021, 02:34 PM | #2 |
Moderator
Re: 700r problems with reverse
1/ Check fluid levels
2/ Here is a list of issues that can cause No Reverse...in a 700 R4 The bold listings are most likely the issue... Input Housing Assy: - 3-4 Apply ring stuck in applied position. - Forward clutch not releasing. - Turbine shaft seals missing, cut or damaged. Oil Pump Assy: - Retainer & ball assy missing or damaged. - Stator shaft seal rings or grooves damaged. - Stator shaft sleeve scored or damaged. - Reverse boost valve stuck, damaged or misassembled. - Cup plug missing. - Restricted oil passage. - Faces not flat. - Converter clutch apply valve stuck. Reverse Input Clutch: - Clutch plate retaining ring out of groove. - Return spring assy retaining ring out of groove. - Seals cut or damaged. - Restricted apply passage. - Porosity in piston. - Belleville plate installed incorrectly. - Excessive clutch plate travel. Lo & Reverse Clutch: - Clutch plate retaining ring mispositioned. - Porosity in piston - Seals damaged. - Return spring assy retaining ring mispositioned. - Restricted apply passage. Time for a shop to look at it...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
01-05-2021, 02:46 PM | #3 |
Junior Member
Thank you AussieinNC
01-06-2021, 11:27 AM | #4 |
Junior Member
Got it in reverse but first gear had some grinding then disappeared went it kicked into second. Proof is in the pan. Time for a rebuild
01-09-2021, 08:26 PM | #5 |
Broken sun shell? I have replaced hundreds
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
01-09-2021, 08:49 PM | #6 |
Moderator
Bigdav160 is most likely correct....when they break the debris can go into clutch packs causing lockups....
Shop time ....
