Old 01-16-2021, 07:47 PM   #1
Artie in Miami
Add a Leaf ?
A few years ago, I bought a set of "add a leaf" spring to add to my 1990 GMC 2500 Suburban. As luck would have it, I cannot find the pack of installation hardware that came with the kit !! What hardware will I need to finally install these babies ? I notice that when I tow my boat, the rear of the truck goes way down and I am hoping adding these will help that.
Artie in Miami is offline   Reply With Quote
Old 01-16-2021, 09:26 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Add a Leaf ?
I bought an add-a-leaf kit for a truck when I was 16, Trail Master IIRC. It didn't come with any hardware. You had to disassemble your spring pack, put the leaf somewhere in the middle, and reassemble. Much stiffer ride but it worked.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-17-2021, 09:32 AM   #3
sweetk30
sweetk30's Avatar
Re: Add a Leaf ?
Longer center pins . Longer u-bolts . Knowing how to work on leaf spring packs or you can get hurt .
Add-a-leafs help yes but ride stiffer when not needed .
I would do timbren style bump stops . Only come in when needed .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
