Old 01-21-2021, 08:57 AM   #1
expedition
rear suspension
64 gmc .I dropped my rear suspension 7 inches ,do i need to install the c-notch i bought already or would air shocks be sufficient with out c-notch ,right now i have about 1 inch of travel on suspension before rear end hit bump stops . I would like to load my softail harley deuce in the box in the future it weighs about 700 lbs .
expedition is offline   Reply With Quote
Old 01-21-2021, 09:19 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: rear suspension
With 1 inch of travel unladen, you need to notch it. I'd imagine if you bounced on the rear of the truck your body weight would bottom it out currently and you probably weigh a lot less than the motorcycle does.
Old 01-21-2021, 01:29 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: rear suspension
What exactly did you do to lower it 7”.
Drop springs, and lowering blocks?
Did you add an adjustable track bar?
Did you add rear shock relocators?
Personally I would add the c-notch and swap out the coil springs for some 2600 air bags on schrader valves. Then you can air up any time you need to haul anything. Plus you would be able to use quality shocks.
I’m not a fan of air shocks.
Keith
Convert to disc brakes.
Old 01-21-2021, 01:33 PM   #4
SCOTI
SCOTI's Avatar
Re: rear suspension
x2.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-21-2021, 08:51 PM   #5
expedition
Re: rear suspension
Thanks for the quick reply .I got lowest spring i could get plus 2 inch blocks and shocks re-locators bracket installed ,love my stance now but no suspension and i wanna be able to load my deuce in the back of the truck if i need too , i know you suppose to c-knotch below 5 inch but heard that i may get away without c-notch if i use air shocks .Just wondering if anybody use air shocks before and i didnt have the bike when i did my suspension .Thanks fellas
Old 01-21-2021, 10:30 PM   #6
cwcarpenter98
cwcarpenter98's Avatar
Re: rear suspension
With only 1" of travel, air shocks won't help enough
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-22-2021, 10:51 AM   #7
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: rear suspension
C Notch and air bags. Even if you do what I call a pipe notch, you gain at least 2 more inches of travel without cutting into the floor. I would also box the frame in that area for more strength.
Steve
1997 Tahoe LT 4D 2WD (DD)
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
