01-23-2021, 02:04 PM | #1 |
Header question
Ok so I am looking at headers for my 70 C10 and have a question. My truck kiss a 3 on the tree with a 350 and I'm wanting to put long tubes on it since I am nearing the end of my restoration. I mainly want them for looks. This will be a cruiser and car show truck. My only problem is the only ones I find that seen to say work with 3 on the tree are ceramic coated. Thats fine but I still need to do my initial engine break in process. Every one says that the break in process will ruin the coating. I found summit has an uncoated set that I like but they are out of stock and estimate 4/22/21 before being available. Am I good to just use the ceramic ones? Here is a pic of the engine. Oh and ignore the wheels . I will be using the 15x8 6 lug Ralley wheels.
01-23-2021, 05:37 PM | #2 |
Re: Header question
If you have a old pair of exhaust manifolds rig them up to do the break in and then install your new headers.
01-23-2021, 07:41 PM | #3 |
Re: Header question
That is probably what I will need to do. Just don't want to spend extra money for nothing on the exhaust. I have the old rams horns but I will need gaskets and bolts.
01-23-2021, 09:54 PM | #4 |
Re: Header question
If you are just breaking it in, buy the cheapest set of headers you can find and some collector mufflers to do that. Then put your coated headers in and hook up all the neccesary clutch linkage when that is finished. You certainly don't want to buy a GOOD set of uncoated headers and then have to get them coated.
Heddman was the only header I could find that really did work with my Jimmy and the SM465. But the Corvette rams horns are a better solution if you are less than 400 hp...
01-23-2021, 09:56 PM | #5 |
Re: Header question
Let me check with one of my buddies and see if he has a old set of headers. Probably just postage to get them there.
01-23-2021, 11:03 PM | #6 |
Re: Header question
01-24-2021, 04:04 PM | #7 |
Re: Header question
The Corvette rams horns drop straight down near the crossmember and there's no room to connect head pipes. As I recall, the exceptions are trucks that mount the engine farther back, such as 69-72 4WD trucks and 67-68 2WD and 4WD trucks..
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 01-24-2021 at 07:58 PM. |
01-25-2021, 06:03 PM | #8 |
Re: Header question
Sorry no luck on the headers. He got rid of a bunch of stuff and the two sets of headers went too.
01-25-2021, 06:57 PM | #9 |
Re: Header question
Not trying to hijack the thread but what exhaust manifolds were stock on a 72 C-10? Straight down or angled back.
01-25-2021, 09:20 PM | #10 |
Re: Header question
They were angle on both sides.
01-25-2021, 10:25 PM | #11 |
Re: Header question
A good exhaust shop can make it happen, but you are right, moving the motor back to the 6 cylinder spot allows for maximum clearance. Also improves the weight balance of the truck. But requires lots of work and a new driveshaft.
01-26-2021, 10:16 AM | #12 | |
Re: Header question
My 69 has a ton of space between HEI and firewall, but I'd rather it was moved back. However, as you said, it's a lot of work (and parts) just to use 2.5" straight drop rams horns. I wish the aftermarket would make 2.5" or even 2.25" angled rams horns. The stock replacements are necked down to 1-7/8" or less.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
01-30-2021, 11:11 AM | #13 |
Re: Header question
Thanks for all the advise. I decided yesterday that I will reinstall the original manifolds for the initial break in then worry about the headers at a later date.
01-30-2021, 01:27 PM | #14 |
Re: Header question
The 2 1/2" straight drop rams fit in the stock V8 position in a 2 wheel drive .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
01-30-2021, 01:34 PM | #15 | |
Re: Header question
Nice looking engine!
01-30-2021, 01:44 PM | #16 |
Re: Header question
67 , this is the bend required to clear the starter ( and still be easy to drop) the clutch linkage and the cross member , It's a 4" bend .
01-30-2021, 02:41 PM | #17 |
Re: Header question
Your engine is mounted in the rearward position, right? In 69 they started using the forward mounts for V-8s.
01-30-2021, 03:00 PM | #18 |
Re: Header question
No , It was originally a l6 frame and I removed the 6 manual trans cross member and replaced it with a stock V8 manual trans cross member to have the engine sit in the stock V8 forward location and run a Muncie M-22 4 speed , You can see it's mounted in the forward position .in 67 they used the front holes to mount a V8
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 01-30-2021 at 03:10 PM. |
