01-31-2021, 06:45 PM | #1 |
Active Member
wiring harness id
underdash courtesy lights?
01-31-2021, 10:53 PM | #2 |
Old member
Re: wiring harness id
That doesn't look like mine. But not sure if mine is factory are not but I like having them. That looks more like the cig lighter and AC maybe. The wire on the left has the funny plug on the end for the cig lighter.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 02-02-2021 at 11:44 PM. |
01-31-2021, 11:20 PM | #3 |
The one on the right is for the lighter. The one on the left looks like it's an extension to tap off of an existing power source. The courtesy light wiring is white and orange, as in Andy's picture.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
02-01-2021, 06:38 PM | #4 |
This thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=743074 ...has a picture of the connector at the cig lighter. It is the only connector like it on our trucks that I know of. The one on the left reminds me of the wire that plugs into the "CIG" terminal at the fuse box. It should plug into that terminal at the "Y" end (left connector at the "Y" in the photo). If the one in the right has that connector for the lighter, then I think the opposite end connects to the short leg of the "Y". It's been to long since I rewired my truck to be 100% positive. If the one on the left has the funky connector for the lighter then the one on the right should plug into the short leg of the "Y" and powers the blower relay.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
02-02-2021, 02:26 AM | #5 |
Your left harness is for the cigarette lighter. The one on the right is for the radio. The connector on the right harness looks weird because it inserts into the factory speaker connector that plugs into the radio. Looks like they both are in good shape
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com |
