Upgrade to Crate engine HP?
1970 Jimmy 4x4 2.5” all spring lift 33” tires. New thread, since different question.
The turn key zz6 405hp GM crate motor is at my top end of my engine upgrade budget. But is that too much HP for stock driveline??? I would have 350trans rebuilt to handle. Have Stock 205 xfer. Stock axles and driveshafts. Haven’t verified gear ratios and if the spid mentioned “posi” is still in there. At a minimum new joints/shaft. Not planning on any crazy muddying, rock crawling or racing. But also don’t want to be sitting on the grenade scared to push the pedal �� Also Not wanting to chase parts for axle swaps, LS conversions, etc. Looking to put crate engine rebuilt trans and drive. Reason for zz6 was the heads and being roller cam & lifters and of course the extra HP ![]() Free time is what’s limited. Thanks Last edited by k-nuts; 02-03-2021 at 06:45 PM. |
#2 | |
Re: Upgrade to Crate engine HP?
Carpe manana
![]() ![]() Join Date: Dec 2010
What’s the present gear ratio? 3.73 might work well with the combo.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#4 | |
Not sure, I need to check! Thanks Last edited by k-nuts; 02-03-2021 at 11:18 PM. |
![]() Join Date: Sep 2016
You might consider the HT383 as well, it will make better torque in the lower RPM ranges. You'll have to wrap that ZZ6 up to 5000-6000 RPM to really take advantage of all that power.
You ever have one of those mornings where you wake up owning more trucks than you did the night before? 1972 K5 1972 K10 1967 K20 bucket truck |
Make sure to budget for EFI. Carbs are good for wheel chocks, IMO.
