Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 02-14-2021, 07:11 PM   #1
72MARIO
72MARIO's Avatar
1967 K30 Longhorn 4x4 6.0 4l80 205 Build.
I bought this frame back in 2013 from Rusbuilt. We drove down to Tennessee from Ontario Canada in our 1968 suburban. It was a long loud flowmaster drone trip with the 3:73 gear and no OD. When we got back home.I parked the suburban for the year.
Anyways here I am 8 years later finally building it. I really didn't have the space till this year. I will be converting it to 4x4 adding 14 bolt with 4:56 gears and a locked Dana 60 front. I will be adding pitcures to catch up to where the frame is at this point. Once the frame is complete I will be moving the 1967 body over to the longhorn frame. When I built the truck 13 years ago I couldn't find a 1 ton frame so I converted the 1/2 ton frame to 3/4 ton. I used dana 60 rear and 8 bolt front. It has work well over the years but always at it 's weight limit.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-14-2021, 08:03 PM   #2
Getter-Done
Getter-Done's Avatar
Re: 1967 K30 Longhorn 4x4 6.0 4l80 205 Build.
Great story
I am following along for the Build.
84 Chevy K-20
Old 02-14-2021, 08:36 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
Nice, that’s gonna be an awesome build. I’ve been on the hunt casually for a longhorn frame for a little bit now. They don’t come up for sale all my that often around here. Can’t wait to see it come together.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 02-14-2021, 09:07 PM   #4
72MARIO
72MARIO's Avatar
Going to have to load the pitcures one at a time. I have no idea why there flipping?
For.the front springs I decided to use 1973 spring length of 47". I need this truck to ride nice so I ordered Off Road Design Alcan springs. I had them keep the spring lift to a minimum should be around 2" . It's a work truck and the deck height needs to stay around 38". In the rear I used 1973 56" 2800lb springs . The hangers are k20 front and k30 rears with ORD HD shackles. The frame is currently sitting with a slight rake which is perfect. .
2005 TAHOE DD
Old 02-15-2021, 10:30 AM   #5
dozerbill72
dozerbill72's Avatar
Isn't using the longer front springs in the stock front location going move your front axle back a few inches?
dozerbill72 is offline   Reply With Quote
Old 02-15-2021, 12:30 PM   #6
72MARIO
72MARIO's Avatar
I had the centering pin placed at the correct spot for 1972 springs which is 22" from the main eye.
2005 TAHOE DD
Old 02-15-2021, 10:20 PM   #7
Getter-Done
This build reminds me of another one.
My Internet friend fishnixon has a Similar build.
Here is the link Below to his build.
It Could possibly help with you project.
Giving you more idea's so you can spend more Money
Link: https://67-72chevytrucks.com/vboard/...=739265&page=9
Hope this Helps You
84 Chevy K-20
Old 02-16-2021, 12:54 AM   #8
72MARIO
72MARIO's Avatar
Hope this Helps You
Thanks. I have spent lots of time reading 7dee2 s build. I am pretty far along on the build already. Posting the pitcures is really difficult for some reason they keep flipping..
http://67-72chevytrucks.com/vboard/s...d.php?t=645614
2005 TAHOE DD
Old 02-16-2021, 01:10 AM   #9
72MARIO
72MARIO's Avatar
Here are a few of the engine mounts. I decided to use 1973 up style because I wanted the improved engine mounts. I had to slice the top of the mounts off and shorten them. Once cut the flange was bolted into the frame it was then tacked in place. I welded them up on the bench. The engine crossmember is from ORD its the big block engine crossmember. I took my time using the frame alignment holes to make sure everything was square. The frame was kept level while fitting the crossmember.
2005 TAHOE DD
Old 02-16-2021, 02:12 AM   #10
Richard
Looks like you are pretty handy with metal work. Will be following your build. Regarding your pictures. If you upload to a windows computer, simply open them with paint and save. You can always rotate them with the program as well.
Richard
Old 02-16-2021, 09:50 AM   #11
57taskforce
All about them K’s
Did you build that LS engine crossmember largely from scratch? Damn fine work!
Tyler
Old 02-16-2021, 07:56 PM   #12
72MARIO
72MARIO's Avatar
The crossmember is from Off Road Design. I am not that skilled LOL!
2005 TAHOE DD
Old 02-16-2021, 08:09 PM   #13
72MARIO
72MARIO's Avatar
I have the engine set in place. Sitting pretty at 4.5° down relative to the frame. I had to place the transmission crossmember inside the frame rather than suspended under the frame like some 1981 up trucks come from the factory. The oils pan is close to the crossmember on the passenger front corner. I will be using thicker steel adapter plates and new engine mounts. That should fix the minimal clearance l have currently.
2005 TAHOE DD
Old 02-16-2021, 08:23 PM   #14
72MARIO
72MARIO's Avatar
I got the lower tab of the cab mount modified. I copied all the front spring placement from a 1976 military frame. This is where the shackles landed. Not a problem. Just another thing to modify.
2005 TAHOE DD
Old 02-16-2021, 10:33 PM   #15
Getter-Done
Flip for Ya.
What works for me on the Picture Stuff.
I load them to the PC
Then (edit) every one.
Then (always) hit the Preview post button to see if I messed up.
By the way Great Job
84 Chevy K-20
Old 02-16-2021, 11:06 PM   #16
72MARIO
72MARIO's Avatar
Thanks for fixing them. I am posting from my cell phone. I will have to try loading them on the computer
2005 TAHOE DD
Old 02-18-2021, 12:41 PM   #17
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I'm joining in to watch......
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 04-11-2021, 01:38 PM   #18
birdistheword
birdistheword's Avatar
Cool build and looking forward to following along with it. I'm in the process of gathering parts for a 6.0L, 4L80E, NP205 swap along with some suspension upgrades.
Erik
1969 Chevy K20 6.0L/4L80E/NP205
1971 Chevy C30 Cheyenne Longhorn 454/TH400
1979 Chevy K30 dually currently in pieces
birdistheword is offline   Reply With Quote
Old 04-15-2021, 12:08 AM   #19
72MARIO
72MARIO's Avatar
Man I wish it was easier to post pitcures. So time consuming adding to this thread....just like building the truck haa. It's basically done as of now. I have a few loose ends like fuel lines and bleeding the brakes and its ready to work. I have been in the shop 7 days a week most days past midnight.
2005 TAHOE DD
Old 04-15-2021, 12:30 AM   #20
Getter-Done
Flip for ya.
Great job
And you have a Great place to work on your truck
84 Chevy K-20
Old 04-19-2022, 09:17 AM   #21
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Mario, any progress on this guy?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 06-12-2022, 08:38 PM   #22
72MARIO
72MARIO's Avatar
Well it's been working great for a year. Had a rear driveline operating angles that need to be resolved this winter. Much better now but I really need to lower the transfer case to further reduce the rear u joint angles. At least I can do 70mph now smoothly.
2005 TAHOE DD
Old 06-12-2022, 08:52 PM   #23
Ol Blue K20
Nice! Great to see progress!
Dale
Old 06-12-2022, 09:14 PM   #24
57taskforce
All about them K’s
Awesome work!
Tyler
