Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-28-2021, 03:39 PM   #1
hotrod1
56 - autocross
hotrod1's Avatar
Cage outriggers or cab mounts or both?
Need advice, please.
Have a Chevy 56 that will be used for autocross. It will have a cage but won't need to pass NHRA standards.
I am building a new chassis. The old chassis had cab mounts and separate outriggers for the cage to the chassis. They were very close together and it seemed redundant. Was thinking about moving the cab mounts to the outriggers as well. Is this a good idea and how would you do it? Was not sure about using cab spacers either.
Hope this all makes sense. Opinions, please?
Thanks in advance
hotrod1 is offline   Reply With Quote
Old 03-03-2021, 09:33 AM   #2
regan wilson
regan wilson's Avatar
Re: Cage outriggers or cab mounts or both?
Can you post some pics?
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 03-12-2021, 06:58 PM   #3
PGSigns
PGSigns's Avatar
Your new chassis will make the choices for you. As a general rule I always put solid mounts in anything that will get raced. No matter the type of racing the stiffer you can make the overall structure the better your ability to tune the suspension. If the chassis flexes you have a added spring of sorts in the chassis you cant really control.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
