1970 4X4 Gas tank relocation
I am doing a full frame off restoration of my truck and will be relocating the gas tank to under the truck as I am going with EFI and want it out of the cab. All the kits appear to work only for 2WD trucks as the 4x4 has a frame cross member in the area where the tank lives. What do the 4x4 guys do to relocate the tank? Thank you
Re: 1970 4X4 Gas tank relocation
I have done it using suburbon fuel tank cross members from a square body and a 96 burbon tank
Done it with a 76 burb tank as well though i went back to in cab tank after i picked up a fleetside box i didnt have the skills or welder at the time to add a gas door |
Relocate the one on the truck and buy another crossmember to support each end of the tank (straps)
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
I relocated my tank to the the rear between the frame rails on my 1970 C10 4X4. Went with a Boyds Welding tank. It has tabs on both sides that rest on the lower frame rails. Perfect fit, sturdy. No issues what so ever.
Roto Reuter thats the name...
![]() Join Date: Feb 2010
I did a 5.3L swap in my 70 K10. I used Rick's Tanks made in Texas. Stainless steel tanks. High quality, but pricey. IMO well worth it.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
![]() Join Date: Mar 2003
I can also give a thumbs up to Ricks Tanks. Had them make me a custom tank for my flatbed. If my math is correct it will be about 45 gal
