Opinions on repop headlight buckets
My headlight buckets are no good and I'm looking to get some new ones. Do you guys have opinions on if the aftermarket ones work okay and also the trim ring that holds the headlight on?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
![]() Join Date: Jul 2006
Re: Opinions on repop headlight buckets
Of all the repop parts I've purchased, the headlamp buckets were to most identical to the original pieces.... I don't have an opinion on the trim rings- I was able to polish mine up pretty well
Project Family Values Build Thread Vehicles/Projects: -1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon... Pleasure in the job puts perfection in the work. -Aristotle |
Thank you for the feedback. That is good news. I will see if anybody has any thoughts about the trim rings
I would not order the buckets from classic ind. I did and one does not fit well and the other was missing the spring hole
Thank you for the information. I was going to get everything from GMC Pauls
