03-12-2021, 12:41 AM | #1 |
Setting Bed Question?
I Heard I Need To Add Some Spacers In Between The Bed Sills Before I Set It Down On The Frame On My 69 C10.
Where Do The Spacers Go and Do I Need To Add Them? Posted via Mobile Device |
03-12-2021, 08:54 AM | #2 |
Re: Setting Bed Question?
When I took the bed off of my 72 there were no spacers. Metal on metal.
03-12-2021, 10:14 AM | #3 |
Thank You.
Was Referring To The Bed Wood When Bolting The Sills In Place Posted via Mobile Device |
03-12-2021, 10:35 AM | #4 |
Same
03-12-2021, 11:02 AM | #5 |
Is the reason for the spacers misalignment with the cab?
If this is the issue its the cab mounting that needs attention not the bed. If I am way off base maybe post some pictures of the issue? |
03-12-2021, 04:22 PM | #6 |
When I put my bed back together after replacing the wood, and cleaning and painting the sills, I cut squares of tool box liner to sandwich in. Probably not needed, but I did it..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
03-12-2021, 08:52 PM | #7 |
laying low
There are some square 1/4" thick rubber pads that go in between the frame rails and the cross sills available from Classic Parts and maybe LMC, GMC Pauls, etc.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
