Old 03-18-2021, 06:07 PM   #1
eric8
Wire/Connector ID help
Have a factory solid blue wire with a single pin connector that is unused on my truck. Very curious what it is for. It exits the main engine harness back by the bellhousing mating area on the driver's side. This is on a virgin 77 C10, 350 engine, 3 speed manual transmission.
Attached is a photo
eric8 is offline   Reply With Quote
Old 03-18-2021, 06:17 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: Wire/Connector ID help
Solid blue. Possibly your truck was converted to gauges and that's the oil pressure lamp switch wire.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-18-2021, 06:23 PM   #3
eric8
Good thought but 100% sure this has factory gauges with the OE mechanical oil pressure gauge copper line exiting the block. Maybe the trucks without gauges had an electric oil pressure switch that this wire went to? For the dummy light? And all trucks had the same engine wiring harness regardless of how they were optioned?
Old 03-18-2021, 06:52 PM   #4
Dead Parrot
77 may be too early but on trucks with electric choke carbs, there was often a connection to an oil pressure switch that kept the choke heater from getting power until there was nominal oil pressure.
Dead Parrot is offline   Reply With Quote
Old 03-19-2021, 12:21 PM   #5
hatzie
Moderator
hatzie's Avatar
Open up the 1977 GM Light Truck wiring diagrams.
In 1977 the V8 OIL warning lamp was Circuit 31. It's a Dark Blue single wire from the instrument cluster, through the bulkhead, to an overmolded Female Packard 56 connector.
The 1977 wiring diagrams show that there was a choke heater oil pressure switch on some models but it was a two terminal switch with Light and Dark Blue wires in one terminal and two Brown/White wires in the other terminal.
The four wires on the oil pressure switch connection, for the trucks so equipped, are circuits 901/931 & 141A/141B.
  1. Circuit 931 is Dark Blue and appears to run back through the bulkhead plug to the instrument cluster using the same slot as Circuit 31.
  2. Circuit 901 is a Light Blue wire to the Choke heater.
  3. Circuit 141B is Brown/White to the idle stop solenoid from the wye on the oil pressure switch.
  4. Circuit 141A is Brown/White to the bulkhead plug and connects to two circuits 141 & 43 on the bulkhead socket inside the cab. 43 is the Yellow radio power wire. 141 is ignition switched power ACC & ON.
If your truck has the manifold stove choke coil then I doubt your truck is equipped with this electric choke wiring.
The only other Dark Blue wires in the engine bay are the RH Turn and the Wiper motor.
