03-23-2021, 06:30 PM | #1 |
Removing Jimmy Emblem.
Any tricks to removing the emblems without having to unbolt outer/inner fenders? Thanks
03-25-2021, 07:31 PM | #2 |
Re: Removing Jimmy Emblem.
I'll jump in here since you haven't received any responses yet. Having just put my front clip back together, I really can't see any way you could do that without at least removing the inner fender. Even then it would take a lot of flexibility and patience.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
03-25-2021, 08:53 PM | #3 |
Appreciate the feedback.
Do you happen to know if the reproduced Jimmy emblems are plastic or metal? |
03-25-2021, 11:51 PM | #4 |
I’ve done it with the inner fender in. Not easy but doable.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
03-25-2021, 11:57 PM | #5 |
03-26-2021, 01:23 AM | #6 |
I don’t think I did. You have to use a small wrench and basically lay across the fender. If I did it again the inner fenders would come out. It’s a pain.
03-26-2021, 11:34 AM | #7 |
Mine is a Blazer, so I can't say for sure, but the ones I got are nice, heavy metal.
03-26-2021, 12:13 PM | #8 |
Roadtrip!
I have done it from underneath the rear edge of the fender. You will need patience, and a longer 3/8ths ratchet wrench, and long arms.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
03-26-2021, 12:17 PM | #9 |
03-26-2021, 12:21 PM | #10 |
Thanks! And allot of cuss words I suspect If I can confirm that the reproduced ones are metal, I'll probably just cut the studs on mine. They need to be repainted anyway.
04-04-2021, 09:55 PM | #11 | |
I have yet to see, or have a reproduction item as good as the originals. Pat |
04-04-2021, 11:45 PM | #12 |
