03-24-2021, 09:09 PM | #1 |
Upper radiator hose question
I'm putting a vortec motor out of a 97 tahoe in my 71, I'm using the factory serpentine system too. Has anyone found an upper radiator hose that goes up over the serpentine belt and connects to the radiator? I don't really want to use one of those aluminum flex hoses.
Thanks!
'71 Chevy 3/4 Ton Longbed '22 Chevy Tahoe RST '67 Firebird- 8 sec street car '19 Chevy CC 4x4 Duramax Dually |
03-24-2021, 11:15 PM | #2 |
Re: Upper radiator hose question
I’m running a serpentine system from a 92 K1500 in my 72, I think they are the same. Stock 72 upper hose with a buillet specialties swivel thermostat housing, to tweak the hose routing. 10 years and 40k with zero issues.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
03-25-2021, 12:53 AM | #3 |
When I had a small block in my 69 I had to use a double hose. I looked for quite awhile for a single hose that wouldn't hid the fan on the alt but didn't find one. I ran this for a short time
04-03-2021, 10:09 AM | #4 |
I’m finishing the install of the same. This is mine. I purchased an prebent tube and some nice silicone elbows.
MrBlue 72' C-10 350 TKO-600 Current Project 54' Ford F-100 Life Long Project |
04-03-2021, 10:14 AM | #5 |
laying low
I don't have a serp belt setup but I did use a hose from a 73 to 87 pkup on mine since I used the latter long water pump accessories. It clears the AC compressor better.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
04-03-2021, 04:43 PM | #6 |
Old member
This hose is for a dodge ram truck but I cut one end off and it fits perfectly. The one picture shows what I cut off.
May not be what your looking for but it sure is better than what I had on it before.
