![]() Join Date: Nov 2018
1963-66 C10 Power Brake Booster
Hello
I was wondering if anyone has used Cardone remanufactured brake booster? I am thinking of getting one. How is the quality of the part? Thanks Pete |
![]() Join Date: Jan 2011
Re: 1963-66 C10 Power Brake Booster
I have had good luck with Cardone over the years. For power brake conversions I like using the Captnfab bracket sold here on the forum and the later model booster and master cylinder setup.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#3 | |
Thanks for the input Are you still restoring gauge cluster for these trucks? Mine needs some help. Thanks Pete |
Moderator
![]() ![]() Join Date: Aug 2011
I dont see that booster fitting unless you have one of these on your firewall. Most people go with captainfabs bracket, use the booster.
![]() Join Date: Apr 2009
I’d Be Real leery With Cardone My Buddy Almost Lost his foot There Clutch Flywheel Is Inferior The flywheel Disintegrated in A BBC He Won 7 Million
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
I have about 6 clusters ready to put together. I have just been concentrating the last couple of years on building a new shop and working on my collection of projects that seem to be growing faster than my time to work on em. I can put you something together if you need a cluster.
Jimmy
I have and it works well. Very few miles over the few years I've had it. I had the factory setup and just swapped the booster.
Post Whore
![]() Join Date: Mar 2013
I'll be trying them out for my 64 GMC here soon so I'll let ya know how it works for me as well.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
So does this bolt up to the firewall or do you still need a bracket
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
#10 | |
[ATTACH][/ATTACH] |
Moderator
That's the stock one yes. "Hope" it works on the booster you purchase.
Hello
LoL I’m using the booster in the picture. Pete |
