03-28-2021, 09:51 AM | #1 |
Let's talk steering wheels
Good morning. I would like to see what everyone is using as far as steering wheels go. I am nearing the completion on my 70 C10 restoration and I am needing a steering wheel. I'm a bigger guy and as we know these trucks are a little small inside. My truck is a manual steering setup. My dad daily drove this truck for 30 years and most of that time he had a wheel from a square body in it. I afraid the 17 inch factory wheel will not offer me enough room. Are these wheels specific? I saw a wheel for a Nova I liked a while back at a Classics shop and wondered if it would fit. Anyway here is what I am working with. And also here is kind of what I am thinking as far as a wheel goes. Thoughts?
03-28-2021, 10:36 AM | #2 |
Re: Let's talk steering wheels
I'm 6'2" and 275 , I added PS and a Flaming river tilt column and using the Comfort wheel along with moving the steering wheel /column down to make it more comfortable . Manual steering was one of the first things to go . Have you ever noticed how many trucks have front fender and grille damage. I'm pretty sure that's due to manual steering and drum brakes . Check these threads .
http://67-72chevytrucks.com/vboard/s...d.php?t=540199 https://www.google.com/search?q=cama...7MSNa6H1A5vCwM
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
03-28-2021, 10:42 AM | #3 |
The gm comfort wheel is what I used. Got the complete kit from Ausleys parts when I was in Carlisle
03-28-2021, 10:49 AM | #4 |
It "kinda" sounds like you like the original wheel but just wish it was offered in 15" - it is: https://www.lmctruck.com/1967-72-che...ls-as-original
If custom (or at least non-original isn't a problem), then the one in Mark's post #3 is by far my favorite aftermarket wheel in these trucks. Really like the look of those. Keep in mind that going with a smaller dia wheel without upgrading to PS might get old pretty quickly - there's a reason the originals were so big back in the day. |
03-28-2021, 11:01 AM | #5 | |
03-28-2021, 11:15 AM | #6 |
This is not going g to be a daily driver by any means. I kept it manual steering for nostalgic reasons. My dad bought this truck way before I was born so I grew up riding in this truck. This is also the first vehicle I ever drove and what I learned to drive a manual in. I also kept it 3 OTT. Dad parked this truck in his shop almost 20 years ago and recently gave it to me. I paid for all the resto but we worked on it together. He is a retired auto body man of 46 years. I will take a look at the GM Comfort wheel. Thanks!
03-28-2021, 11:16 AM | #7 |
I'm sure whatever wheel you pick will look good in that fine truck!
03-28-2021, 12:20 PM | #8 |
laying low
turn
You might look into those shorter seat mount brackets too.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
03-28-2021, 12:34 PM | #9 |
03-28-2021, 12:43 PM | #10 |
03-28-2021, 12:58 PM | #11 | |
03-28-2021, 12:59 PM | #12 |
I understand leaving it manual steering, at least for now. Driving a manual steering truck is a unique experience. Myself, I did that with my 68, but I do know that there might come a day when I eventually have had enough of the nostalgia. Vinyl seats that give me third degree burns in the summer make me nostalgic too but it gets a little tiresome.
If you want a small wheel there are a lot of choices, I like the wooden grant steering wheels myself. Most people on this forum are not fans of those but I got my drivers license in the 90s and it is my own personal nostalgia for that era. But a smaller wheel with manual steering is a real workout. Good luck with finding something you like, that works for your ride. Nice truck.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
03-28-2021, 02:37 PM | #13 |
At your size i would recommend a wheel that uses a GM 3 hole wheel adapter. The 9 hole ones that have been presented add a couple of inches to the length of the column.
http://www.spiderautomotive.com/grant838blue.html |
03-28-2021, 08:39 PM | #14 |
Old member
Checkout this thread. I posted several wheels that I have done. Others posted some of theirs also.
60 era cars have some nice wheels. Camaro, corvairs, Nova's all pretty much work except for the hub. But that a easy fix. I got this far on a stock 67 wheel and it's been sitting for 2 years. http://67-72chevytrucks.com/vboard/s...d.php?t=799275 https://67-72chevytrucks.com/vboard/...d.php?t=795131
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 03-29-2021 at 09:16 AM. |
03-28-2021, 11:19 PM | #15 |
Are the 15” repops stiff? The 17s are pretty flexy.
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
03-28-2021, 11:37 PM | #16 |
For manual steering, the wider circumference of the OEM wheels is best -- you get the most leverage. '67-'68 = 16.5'' and '69 - '72 = 17''.
03-29-2021, 01:10 AM | #17 |
Aside from the steering wheel, that’s a fantastic truck you have there! I love the color combo and the fact you have kept it as a 3OTT. I did the same but opted to upgrade to manual.
1971 Custom/10 - 350/3 speed, Orange/White roof |
03-29-2021, 01:30 AM | #18 |
I had a Camaro w/ a Grant wheel on it and the horn button would stick down. I tend to look for GM wheels and if possible wrap them in leather from wheelskins.com. Possible meaning that some wheels have large spokes so the stitching doesn't work well. On an older skinny or hard wheel, I'd first wrap it in rubber, say from an inner tube to make it soft like a modern wheel, then wrap it in leather.
03-29-2021, 05:27 AM | #19 | |
Grant wheels... Never again. I had one come off the steering column in my hand in traffic. They should be outlawed.
03-29-2021, 09:03 AM | #20 |
03-29-2021, 02:22 PM | #21 |
I just put the repop 15 inch from Brother on my truck and it is very well put together. I would highly recommend it if you are wanting to keep the original look.
03-29-2021, 03:18 PM | #22 |
I am the same size as you. Went with a 14" wheel off ebay. I also installed a shorter steering column. There is a thread here somewhere that shows you how you can move the stock steering column closer to the dash and gaining you another 2"
03-29-2021, 04:53 PM | #23 |
Looks like I'm a tad late, but here's my set up for thoughts. I have a 71/72 wheel and an early 80's wheel. I ended up going with the 80's version, mainly because I wanted a little more room. I'm 6'3" 240 and the 71/72 wheel was just too big. I think the 80's wheel is roughly 15"? I like it so far, although I haven't driven it yet.
1971 C10 - Hugger Orange/White My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197 LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460 |
03-29-2021, 04:57 PM | #24 |
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Administrator for help.
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l Last edited by LockDoc; 04-02-2021 at 11:54 PM. Reason: WTB by Non-Premium member |
03-29-2021, 05:53 PM | #25 | |
