Which coolant
I'm finishing up my C10 restoration and I have installed a new aluminum radiator. Do I need to run the pink coolant since the radiator is aluminum or can I still run the green? The engine has been rebuilt so there is currently zero coolant in the engine.
![]() Join Date: Dec 2009
Re: Which coolant
Good Question.
Then, what is the best antifreeze for aluminum radiators? Zerex G-05 Antifreeze/Coolant 1 Gallon It is one of the best coolants for aluminum radiators. It employs the Hybrid Organic Acid Technology (HOAT) to provide ultimate protection from rust and corrosion designed for both gasoline and diesel engines. https://www.zoro.com/zerex-antifreez...specifications .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
![]() ![]() Join Date: Oct 2014
Re: Which coolant
Unless you are using a newer engine, I've always used Peak Global in all my older vehicle including my motorcycles. It's phosphate and silicate free. I just don't buy the 50/50 mix, as there's no reason to pay for water.
Re: Which coolant
The instructions that came with the DeWitt aluminum I have called for any extended duty antifreeze but to dilute it 50/50 with distilled water or the warranty would be void.
Re: Which coolant
In that case, it's best to do what the warranty calls for. BTW, when I said I don't buy the 50/50 mix, I meant just that. I buy straight coolant and then add my distilled water, since it's much less expensive that way.
![]() Join Date: Dec 2013
Re: Which coolant
I remember in the 90's the red eating aluminum intakes , I don't think I've ever bought a gallon of it . Here's Champion radiators opinion on it .
![]() https://shop.championcooling.com/art...Color-Do-I-Use
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
![]() Join Date: Mar 2003
Re: Which coolant
Just make sure the radiator has a good ground and there shouldn't be an issue
Re: Which coolant
I do the same . Distilled water is 88 cents at the local store, the instructions just said to use either the pre mix or add distilled water at the 50/50 ratio
Re: Which coolant
I have always used Prestone mixed 60/40 with distilled water i do live in a climate it can be more than -40 in the winter
#10 | |
Re: Which coolant
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
#11 | ||
"I ain't nobody, dork."
Re: Which coolant
Been using plain ol' Prestone green coolant mixed with distilled water 50/50 for the last 12 years with an aluminum radiator. Not one single problem.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
![]() Join Date: Mar 2005
Re: Which coolant
I'm bad I guess. I have a standard brass radiator and am using 50/50 mixture of the green and just regular water out of the hose. Never thought about distilled water. It's been a year now, maybe time for a flush.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
#13 |
Re: Which coolant
Copperisnt as sensitive to minerals in the water . But it's still a good idea to use distilled .
#14 |
Re: Which coolant
In my C10 (copper rad) I use Prestone 50:50 premix. I get it at WallyWorld and it's pretty inexpensive. Never had a problem with it. I have also purchased the 'concentrate' version and dilute with RO water.
In my newer cars I always use the crazy spendy factory fluid.
1971 SWB step side: Original NM Forestry and then NM Fire truck |
#15 |
![]() Join Date: Nov 2018
Re: Which coolant
Here's some good info on coolants and why/which one to choose.
https://www.autozone.com/diy/trustwo...-of-antifreeze |
#16 |
Re: Which coolant
Perfect timing. As I am hoping to reinstall my engine in the truck this weekend. I better pick up some green antifreeze and distilled water!
#17 |
![]() Join Date: Feb 2000
Re: Which coolant
I'm partial to using AMSOIL coolants.
https://www.amsoil.com/p/low-toxicit...e-coolant-ant/
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
#18 |
Re: Which coolant
same here never a problem , now on the other hand I did have a tester that went bad over the summer. went to drawer and pulled out tester , was changing antifreeze for winter so the tester sat there for one year. any way changed antifreeze and it kept saying low , so i mixed stronger and stronger. and then the light went off in my head , there is no way it can be that weak. went and got another tester new from store, and bingo it went bad over the summer sitting there. was good for 45* below tho.
#19 |
Re: Which coolant
#20 |
Re: Which coolant
Dang it! Late to the game as I just filled my cooling system with Dex-pink stuff.
MrBlue 72' C-10 350 TKO-600 Current Project 54' Ford F-100 Life Long Project |
#21 |
![]() Join Date: Apr 2016
Re: Which coolant
Nobody has yet mentioned Evan's waterless coolant that I see in catalogs. I've been wondering if that's snake oil. https://www.evanscoolant.com/products/
#22 |
Re: Which coolant
It's not too late to flush it. I got rid of that Dex-Cool coolant in my '02 Z28, flushed and filled with Prestone. Glad I did.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
#23 |
![]() Join Date: Dec 1999
Re: Which coolant
My whole life been lazy regarding distilled in a radiator. Never had one fail due to corrosion. Maybe I am lucky, usually not. Distilled water is contaminated as soon as it is opened and poured into the system. There are actually articles out there saying distilled water is missing things so it tries to take them from areas it contacts actually causing corrosion. Do not understand the need for a ground. Water conducts electricity. Waterless coolant is for track use. No other reason to use it.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 04-04-2021 at 01:53 AM. |
#24 |
Re: Which coolant
The dissolved minerals and solids inside of water are what conducts electricity, water itself does not. Tap water will conduct electricity, distilled water will not. Maybe that's part of the reason for grounding and corrosion.
72 C10 lwb fleetside -stock 350/350 combo |
#25 | |
Re: Which coolant
