![]() ![]() ![]() Join Date: Jan 2018
WTB Clutch Linkage & Door Latch Parts
Was underneath my truck yesterday and noticed that the clutch linkage rod is about half way worn through. I did see the replacement that's available online, but I'm not sure of the quality of it.
I need the rod that goes from the clutch pedal to the z-bar. I think I probably also need a z-bar as the hole has gone egg shaped from wear. (Edit to add: Now that I look again at the pictures, maybe I don't need the z-bar.) Was there some sort of bushing from the factory that was supposed to be there? On the door latch stuff, I need the latch and striker for the passenger side. Both are heavily worn and I can't get the passenger door to close good at all. I could also use a passenger window regulator in good condition, but that would be kinda costly to ship, so I might just try rebuilding the one I have. Any input is welcome here
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson Last edited by cwcarpenter98; 03-28-2021 at 09:23 PM. |
![]() Join Date: Aug 2008
Re: WTB Clutch Linkage & Door Latch Parts
You going to be at Commerce this weekend?
![]() Join Date: Mar 2013
I can probably help you out with the door latch items. If I have them, you pay shipping and there yours. Thanks for being a moderator.
I haven't made any plans for this weekend, so that's a possibility
I forgot to specify that I need them for my 63. If that's what you have, it'll probably fit in a USPS flat rate box. Thank you!
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Mine would be for 64 thru 66. Sorry for not picking up on that.
No worries, thank you for your generosity!
I should have specified 63 in the original post and I plum forgot ![]()
Let me know. Probably have all you looking for. Will have to check on clutch piece. Got a length?
I can help with the door stuff if the other guys don't have it
It looks like it's approximately 20". It's a slight challenge to measure unless I take it out of the truck, but I can pull it out for a better measurement if needed. Looks like where it attaches at the pedal is worn out as well, so I probably need to get that piece too
Thank you. I think I'll end up going to Commerce this weekend, but I'll let you know if I don't find what I need
![]() Join Date: Aug 2020
I have a clutch linkage rod with minor wear if you want it - cost me nothing. But . . .
I cut my existing rod, threaded the rod and then added Heim joints. I eliminated the friction of metal on metal. And on the clutch part that egg shaped, I welded it and re-drilled the hole. |
Thanks for the offer of parts, guys. Dwayne has all the parts that I needed this go around, so I'll be one stop shopping at Commerce this weekend
#13 | |
I did see that mod, but unfortunately for me, I don't have a tap and die set yet and my welder is back home in Woodstock while I'm in Milledgeville till the end of April. Before I install the new to me parts, I'm going to look into using either a nylon or bronze bushing to take up any slack keep it from wearing through again
