![]() Join Date: Apr 2017
Rear Sway Bar
My 69 K25 previously carried a slide-in camper and has a very beefy sway bar installated in the rear. I’m assuming that the truck would probably ride better without it but looking for input. Should I boot it?
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
Who Changed This?
![]() Join Date: Jan 2013
Re: Rear Sway Bar
If it's pushing into corners (understeer) remove it, if you don't plan on carrying any loads.
Re: Rear Sway Bar
I've been thinking about installing one of these for a while but the kits I've seen didn't have a beefy sway bar. I'm kinda interested in how that rear sway bar is attached and the hardware required.
Post Whore
![]() Join Date: Feb 2016
Re: Rear Sway Bar
The sway bar isn't likely to be the culprit for the rough ride. It is highly likely the sprng packs (assuming leafs) are the heavy duty version or an aftermarket upgrades. The sway bar is not factory so it is likely a previous owner upgraded the springs also. Post some photos of the springs and I'm sure someone will be able to tell you what springs you have. That may help you soften the ride.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: Mar 2015
Re: Rear Sway Bar
Sway bars do not change the ride.
The transfer corning loads from one side to the other. I would leave it installed. If you want to experiment just pull the end links and go for a drive. That way you can quickly reinstall it. Which I believer you will after driving it. Especially if drive it with a load. The higher the center of gravity the more important they become. Rick |
Re: Rear Sway Bar
There are definitely extra leaves.
Posted via Mobile Device |
Re: Rear Sway Bar
I have front and rear bars on my 72 long bed. It handles so much better. The thing rides like its on rails. I love it, keep it!
72 C10 lwb fleetside -stock 350/350 combo Last edited by 68 P.O.S.; 03-30-2021 at 05:05 PM. |
Who Changed This?
Re: Rear Sway Bar
Does the SPID say "G50 HD Rear Spring"?
Re: Rear Sway Bar
That spring pack impacts your ride quality more than a sway-bar would for sure.
Re: Rear Sway Bar
2X Accelo. Sway bars do not impact ride they are for controlling body roll.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
#13 |
Who Changed This?
Re: Rear Sway Bar
Bummer. How many leaves?
#14 | |
Re: Rear Sway Bar
Honestly, other than crossing bridges at 70mph and getting launched off the seat, I don’t mind the stiffness. It’s a 52 year old 3/4 ton truck, not a new Escalade. ![]()
#15 |
Re: Rear Sway Bar
#16 |
Re: Rear Sway Bar
To me it looks like your spring pack is a 5 and 1. 5 leaf springs and 1 overload spring. The overload spring is usally flatter than the one you have. The one under the Overload spring, looks to me to be an after market Add-A-Leaf. They are more curved and add height, usually 1 to 2 inches. That may be the reason for the stiffer ride.
#17 |
Re: Rear Sway Bar
Curious about the assertion that a stabilizer bar doesn't change the ride. It limits the independence of the suspension from one side to the other by tying the two sides together. That means that neither side is able to move as freely as it would without the stabilizer bar.
That said, I think the compromise is worth it both front and rear. As others are saying, I would adjust your leaf pack if you are wanting to improve the ride quality. |
#18 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: Rear Sway Bar
https://www.hellwigproducts.com/our-.../?searchq=7401
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#19 | |
Re: Rear Sway Bar
#20 |
Re: Rear Sway Bar
The statement was made that stabilizer bars don't change the ride. The statement wasn't made in comparison to the spring packs, and neither was my response. The OP's original question wasn't relative to his springs either.
#21 |
Re: Rear Sway Bar
Ignore my post & stay on top of it then.
#22 | |
Re: Rear Sway Bar
#23 |
Re: Rear Sway Bar
More pics for attachment pics, leaf pack, and ride height.
#24 |
Re: Rear Sway Bar
From what I've read it always said the rear bar should be thinner, and these two are about as close as you can get, than the front.
#25 |
Re: Rear Sway Bar
Heavy trucks using a sway bar for countering loads will utilize a larger bar diameter vs something that just has a rear bar for a performance benefit.
Vehicles w/non severe/HD/hauling needs typically do utilize a smaller diameter rear bar so it doesn't over power the suspension which could cause the rear to push more vs a set-up having no bar @ all. Trucks are particularly susceptible to this issue since the weight distribution is far greater over the front axle vs the rear.
