Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 03-30-2021, 09:12 PM   #1
Arl37
Left LED Turns signals don't work when headlight turned on.
69 Chevy C10. Direct wire headlights and LED Tail Lights/turn signals. LED s are about 15 months old.
When I turn headlights on dash shows turn signal on but not blinking. When headlights turned off turn signals work fine.
Any thoughts as to where to start would be appreciated.
Arl37 is offline   Reply With Quote
Old 04-01-2021, 06:17 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Left LED Turns signals don't work when headlight turned on.
What kind of flashers do you have on the fuse panel? I ask because I just went thru this with mine (new build) and had to put in LED flashers with a ground to make them work. Also had to use the little black inverter plug they come with.
